Which 10" Tyres
28 replies to this topic
#1 ac427
ac427
  • 679 posts
Posted 29 September 2024 - 06:57 PM
My Mini 1000 HL has a flat rear tyre. The car has original wheels so i think they are 145/80r10 tyres.
I'm torn between putting an inner tube in, getting it sealed to the rim or just getting new tyres.
Would 165/70 tyres require arches?
Looking at the prices i guess it's a toss up between the 145/80 Falken Sincera SN 807 and the Yokohama GT Special Classic Y350 tyre. Which of these do you use on your Mini and why?
#2 absx2
absx2
  • 919 posts
Posted 29 September 2024 - 07:15 PM
3.5" rims need 145 tyres but 4.5" can use 165`s.
The Falken SN807 has to be one of the worst tyres I have used so if the budget allows I would go for the Blockley 145/80R10 tyres as they are really good with a money back guarantee, if not the Marshal 145`s are less lethal in the wet than the Falkens.
I haven`t personally tried the Yoko`s but they should be good but the Blockleys are great and cheaper.
Edited by absx2, 29 September 2024 - 07:23 PM.
#3 ac427
ac427
  • 679 posts
Posted 29 September 2024 - 09:42 PM
In that case i could try the A032R. How do they compare to the A008 ?
I heard the A032R isn't bad in the wet
#4 cal844
cal844
  • 9,638 posts
  • Local Club: TFMOC
Posted 30 September 2024 - 06:03 AM
If you want a 165 width tyre use the A008, good in the wet and brilliant in the dry. If a 145 tyre is needed then the falken sincera is actually decent in the wet (have these on my Clubman Estate)
#5 Lplus
Lplus
  • 911 posts
Posted 30 September 2024 - 07:39 AM
The yokohamas have a very narrow tread.  I'd change them if I could but 4 more tyres is a cost I don't need atm.
#6 mbolt998
mbolt998
  • 395 posts
Posted 30 September 2024 - 08:00 AM
I've got the 145 Falkens. They seem all right to me but it's been a long pause since I've driven the car on anything else so don't have anything to compare with. They do seem a bit slippery in the wet. But is more grip necessarily more fun?
My thinking is also that if I went to wider tyres on my car (which is a bone-stock 1000 and always has been) I would also need to upgrade the brakes (which are drums). In standard form everything is quite well matched to everything else. It's fantastic to drive and it's the car I remember from long ago. Sometimes less is more (although I expect hot minis can be a great deal of fun too).
#7 unburntfuelinthemorning
  • 1,988 posts
Posted 20 January 2025 - 10:11 PM
+1 for Blockley's.  A safe amount of grip in the wet but still lots of fun.
#8 babsbrown
babsbrown
  • 510 posts
Posted 21 January 2025 - 01:17 PM
I use camacs. Mainly for the retro tread pattern, they seem to understeer a bit in the dry, not tried them I'm the rain but apparent they're not great.
Cheap though and dont seem to wear that much.
#9 68+86auto
68+86auto
  • 987 posts
  • Local Club: Queensland Mini Car Club
Posted 22 January 2025 - 12:28 AM
On one mini I installed a set of the SP10s from Japan. I can't say anything about their performance since I've only used them on dirt and gravel "roads".
#10 Cooperman
  • 23,321 posts
Posted 22 January 2025 - 12:36 PM
On a 3.5 x 10 rim the Blockleys are probably the best available.
On a 4.5 x 10 I use A008's, although I think I will try the Blockley 165/70 x 10 next time as they have the old Dunlop SP3 tread pattern.
You should not need wheel arch extensions with a 165 section tyre so long as the datum offset of the wider wheel is the same as the 3.5" wheel.
#11 unburntfuelinthemorning
  • 1,988 posts
Posted 25 January 2025 - 09:27 PM
I had Camac's in the 1990s.  Don't know if they are the same these days but back then they had hardly any wet grip.
#12 MrBounce
MrBounce
  • 2,660 posts
Posted 26 January 2025 - 03:07 PM
Plus the bleeping things never wore out. Horrible tyres!  :lol:
#13 babsbrown
babsbrown
  • 510 posts
Posted 27 January 2025 - 10:31 PM
Nope haha I've had these since 2018 and they still look new 😂
#14 Cooperman
  • 23,321 posts
Posted 28 January 2025 - 10:21 AM
My first Mini, in 1963, had 5-20 x 10 crossplies when I got it. Soon changed to 145x10 Michelin X.
#15 DeadSquare
DeadSquare
  • 3,171 posts
Posted 28 January 2025 - 02:52 PM
I expect you're still trying to wear out those Michelin X.
