Hi all,
After having to put the rebuild of my Mini on hold for many years, I’m slowly starting it up again. Still a lot to do and progress will be slow.
I’m also making plans for the engine. The thing is, I really want to 8 port it. I know it’s expensive and I’m not doing it to have as much power as possible. I just like to learn, try to make it work, and create my dream Mini.
The problem is, I already have a very nice A+ 1275 (now a fresh 1293) with excellent crank, which I don’t really want to replace. However, the standard con rods will not provide enough clearance for the 8 port cam.
Are there con rods available that provide enough clearance, or is it necessary to replace the crank? I contacted MiniSpares, but their I-beam steel con rods (Arrow) will not provide the clearance. SH engineering (Saenz) is unsure.
Any recommendations?
Edited by Fruitmand, 23 September 2024 - 08:49 PM.
