Oil Pump
Posted 14 September 2024 - 02:34 PM
I can drive within a couple hours of warminster today to collect.
Posted 14 September 2024 - 04:05 PM
Somerfords in Calne are probably your nearest.
Posted 14 September 2024 - 04:30 PM
Posted 15 September 2024 - 09:36 AM
Don't forget to put a squirt of oil in the pump and rotate it a couple of times, before you fit it, with a new paper gasket.
Posted 15 September 2024 - 10:52 AM
Make sure the bolts holding the oil pump don't bottom out, as some oil pumps are thinner than others,
Posted 16 September 2024 - 11:01 AM
Hi there and welcome to the forum.
Be sure to strip the pump apart and clean it before fitting. Some are clean and some not. Best not to make any assumptions.
Posted 16 September 2024 - 06:00 PM
Excellent advice, the last 3 I've taken apart to check tolerances all had tumbling media dust left in them, plus it gives you the opportunity to remove the flashing burrs from the casting, I use petroleum jelly in the pump as engines can sit for along time before being installed and fired up.
Shooter
