1275 On Hs4 Idle
5 replies to this topic
#1 Maccmike8
Maccmike8
  • 1,101 posts
Posted 14 September 2024 - 12:51 PM
Hi all.
MOT due on monday so got the mini out for the first time this year. Naughty I know but been so busy with other things.
It wants a little bit of choke to idle.
Its a 1275 Ive converted but running the old 998 HS4. I know its not set up for it but is there something I can do to get it to idle without choke, such as richen it up? increase idle etc?
Thanks Mike.
#2 gazza82
gazza82
  • 2,979 posts
  • Local Club: TMF+
Posted 14 September 2024 - 01:18 PM
If it's cold it will need choke.
#3 Lplus
Lplus
  • 807 posts
Posted 14 September 2024 - 01:46 PM
Hi all.
Thanks Mike.
If it runs ok otherwise when hot but needs choke to stay running at idle, then try richening it up a little with the jet screw.
#4 Maccmike8
Maccmike8
  • 1,101 posts
Posted 14 September 2024 - 02:24 PM
Ive done that, slightly tweaked the idle screw too and much better now. Thank you for your help.
Hi all.
Thanks Mike.
Edited by Maccmike8, 14 September 2024 - 02:25 PM.
#5 Maccmike8
Maccmike8
  • 1,101 posts
It was well warmed up. All sorted now.
#6 Steam
Steam
  • 656 posts
  • Local Club: Victorian Mini Club
Posted 15 September 2024 - 03:42 AM
If it only needs a smidge of choke then it is only needing a little more idle. Adjust the normal idle screw until its happy.
