Petrol Tank Sender Unit
2 replies to this topic
#1 MikeP
MikeP
    Starting My Mini Up
  • 2 posts
Posted 13 September 2024 - 08:38 PM
1980 mini van.
I think I need to replace petrol sender unit.
Do I need to remove the whole tank to get to sender Unit please?
#2 Lplus
Lplus
  • 818 posts
Posted 14 September 2024 - 08:30 AM
1980 mini van.
Haynes manual says yes.  Thats the way I did mine.  It also allows you to clean out the tank and inspect for corrosion.
#3 ac427
ac427
  • 669 posts
Posted 14 September 2024 - 11:33 PM
If the van tank is the same as the Pickup then you might be able to do it in situ but it would be a right bugger of a job.
Much easier to remove the tanks as mentioned above. It's only six screws.
I had my tank out recently, have a look here: https://www.theminif...nternal-pickup/
Edited by ac427, 14 September 2024 - 11:35 PM.
