Hi,
This is my first time working on my mini and could do with some advice from those more experienced.
I started this project due to the engine mount on LH side failing which cause the engine to sink and the fan was ruined due to it catching the housing.
Old Engine mount:
https://imageshack.com/i/pnkTjMqwj
Old Fan:
https://imageshack.com/i/pmzlOxIFj
After replacing the engine mount and Fan i though i was close to finishing the project, however i can't seem to see how the the housing and radiator goes back in correctly. I have read and watched multiple videos of people with different models of mini doing it in different orders.
The first issue i come up against is that the radiator housing mount that attaches to the engine mount sits incredibly close to the fan and does provide enough space for the fan and looks like it would cause the new fan to be shredded like the old one.
New Fan and radiator housing mount too close:
https://imageshack.com/i/pnsPCHwKj
Now if i force and wiggle the housing into place the housing i can get the housing attached but the fan is heavily bending on the housing. With out forcing it the housing and mount will not align.
https://imageshack.com/i/pnD96q2rj
With this project i feel like i have consistently gone 3 steps forward then 2 steps back having to undo everything i have just done to redo it again. I feel like i am so close to completing this but i failing at the end unable to put back in the radiator.
I tried to put the radiator back with the housing attached but was not able to squeeze both past the fan, then i forced the housing to be attached with the fan touching the housing and was not able to get the rear radiator bolts to line up to screw the radiator into the housing.
Any help or advice would be greatly appreciated
