Pickup Metal Pipe Straight To Bulkhead?
Posted 11 September 2024 - 10:38 PM
Is this original or does the underbody metal fuel pipe come all the way up the bulkhead to the carburettor?
Posted 12 September 2024 - 10:44 AM
Overflow pipe.
Posted 12 September 2024 - 12:38 PM
Its normal to have a section of rubber hose in the fuel line - this is how they were originally built
Edited by GraemeC, 12 September 2024 - 06:16 PM.
Posted 12 September 2024 - 04:57 PM
originally the underbody fuel pipe would have connected to the fuel pump on the back of the engine block. the short section of hardline would then be used to connect the pump to the carb
Posted 12 September 2024 - 05:42 PM
Shooter
Posted 13 September 2024 - 09:01 AM
Depends on the year of your Pickup. Early cars up to '69 would have an electric pump on the rear subframe so the pipe at the front would go up to the carb . Later cars would have a mechanical pump on the back of the engine so the pipe would stop lower down .
