Primary Gear Thrust Washer.....i Think Mine Has Disintegrated !
22 replies to this topic
#16 Icey
Icey
  • 1,543 posts
Posted 18 November 2024 - 10:48 PM
So the company that built it (and that are now stripping it) is paying for the rebuild, right? Because that sounds like someone didn’t get it right first time around…
#17 Earwax
Earwax
  • 473 posts
Posted 18 November 2024 - 10:55 PM
that is a shame -  a couple of ales and some thinking out loud regarding diagnosis of cause (not just results) is the best way forward if you are planning on reusing the block). Spider's swarf theory is high on the likeliness scale.
#18 imack
imack
  • 2,018 posts
Posted 19 November 2024 - 08:04 AM
Any indication as to the reason for the failure?
#19 mrmeds
mrmeds
  • 237 posts
Posted 19 November 2024 - 08:07 PM
unfortunately not- they say it was running fine when set up on rolling road- said the cause was petrol in the engine-lol
#20 mrmeds
mrmeds
  • 237 posts
Posted 19 November 2024 - 08:10 PM
they said impossible tosay definitely, as it was so knackered -but petrol in oil- so fuel leak ? over fuelling- ( did have. a sticky choke)
#21 imack
imack
  • 2,018 posts
Posted 20 November 2024 - 09:12 AM
Any photos of the damaged components?
#22 Midas Mk1
Midas Mk1
  • 5,760 posts
  • Local Club: S.U.N.M.C
Posted 20 November 2024 - 09:19 AM
If the engine builder thinks its an external influence to the problem, ie overfuelling, leaking fuel pump, without them actually knowing the cause of failure isn't fixing a problem, unless the issue was internal to the engine that they built.
Personally - i'd be getting my engine back and seeking advice of independent professionals.
#23 mrmeds
mrmeds
  • 237 posts
Posted 20 November 2024 - 11:11 AM
guess that would be a gamble- as cost of transport , inspection etc
