Primary Gear Thrust Washer.....i Think Mine Has Disintegrated !
22 replies to this topic
#1 mrmeds
mrmeds
  • 237 posts
Posted 11 September 2024 - 08:34 PM
see my other recebt threads. re oil presuure ..
Well , looks like the chunk of metal that came out of my sump is most likely a bit of primary gear thrust washer, according to the chap from company that rebuilt engine 21/2 years ago, as he carted it off in a trailer to head northwards for a strip down.
So, what are peoples thought of possible causes? It has done 4500k miles- mainly around town and minor A roads.. Oil has been changed at 300, 660 , 1000 and 4000 miles.
Is it likely to be due to poor float end set up ? Misaligned crank ?
Slightly thinner oil due to slight ingress of petrol ?
#2 whistler
whistler
  • 1,779 posts
Posted 12 September 2024 - 09:24 AM
Don't be surprised if he says that the crank is scrap. I had similar a couple of years ago on a friend's engine. The should where the thrust washer fits to the crank was rounded off.
had to fit a new crank. I did take the knackered crank to AC Dodd who said he could sort it but the cost was high. Hope yours isn't as seriously damaged.
#3 Spider
  • 14,654 posts
Posted 12 September 2024 - 07:40 PM
Sorry, but I just can't see that happening, unless it was assembled by an ape with a lump hammer and if it was that, I'm sure you would have had clutch issues before you noticed an changes in the Oil Pressure Gauge. Also, if it was, it would have a 1 in a million chance of working it's way from where it dropped out to the sump plug, possible but highly unlikely.
As I suggested in your other thread, it's most likely left over swarf that wasn't cleaned out.
#4 mrmeds
mrmeds
  • 237 posts
Posted 07 November 2024 - 08:13 PM
well after 8 weeks up north - the engine is being taken out today !
#5 Cooperman
  • 23,199 posts
Posted 08 November 2024 - 03:13 PM
I have never ever seen a primary gear thrust bearing break up. They have a good bearing area and are very well lubricated.
In addition, any broken parts of one would not be trapped by the sump plug since they would not be magnetic.
#6 mrmeds
mrmeds
  • 237 posts
Posted 08 November 2024 - 03:31 PM
the big bit wasn't trapped by the sump plug, it got washed out by the flow of sump oil , and I found it in the catch  pan when I poured the oil into a waste container, like panning for gold .
#7 mrmeds
mrmeds
  • 237 posts
Posted 08 November 2024 - 03:34 PM
See post no 12 in this thread for pic of metal involved
https://www.theminif...e/#entry3771577
Edited by mrmeds, 08 November 2024 - 03:36 PM.
#8 Midas Mk1
Midas Mk1
  • 5,760 posts
  • Local Club: S.U.N.M.C
Posted 08 November 2024 - 06:34 PM
If it’s taken two months to get to the point of removing the engine, i’d be getting the car out and back!
#9 Icey
Icey
  • 1,543 posts
Posted 08 November 2024 - 10:58 PM
Not convinced that’s got anything to do with the primary gear, but we live to be surprised.
#10 mrmeds
mrmeds
  • 237 posts
Posted 09 November 2024 - 04:20 PM
part of main bearings then ?
It definitely looks brassy rather than steel. There were flakes of the same colur metal amongts  magnetic debtris attached to sump plug.
#11 mrmeds
mrmeds
  • 237 posts
Posted 09 November 2024 - 04:23 PM
theres a dearth of mini speciliasts close to me - the two I did email for quotes to look at engine didn't reply- company up North offered to pick it up for free, and has they rebuilt the engine 2/12 years ago it seemed like a good idea
#12 Spider
  • 14,654 posts
Posted 09 November 2024 - 06:46 PM
They likely get 5 - 10 similar emails a day from tyre kickers. You'd do better to see them or at least ring them.
#13 Icey
Icey
  • 1,543 posts
Posted 09 November 2024 - 09:43 PM
At a complete guess I’d say it’s more likely to be something like the reverse gear bushing or a long forgotten dipstick tube. But how those would be in the sump without obvious other issues (including some horrendous noises) is beyond me.
#14 mrmeds
mrmeds
  • 237 posts
Posted 10 November 2024 - 05:21 PM
as engine was rebuilt, and an A= - would the dipstick tube not me more likley nylon ?
And no horrendous sounds from gear box  or difficuty engaging reverse.
Guess , I'll find out within the next week !
#15 mrmeds
mrmeds
  • 237 posts
Posted 18 November 2024 - 08:22 PM
ok - apparently the whole crank is knackered beyond saving and the maining bearings are confetti
