Leaking Oil
45 replies to this topic
#31 GraemeC
GraemeC
  • 7,418 posts
Posted 13 September 2024 - 07:06 PM
Although be aware connecting the breathers to the carbs now will affect the way it runs - it will need to be tuned accordingly.
#32 PACINO
PACINO
  • 741 posts
Posted 13 September 2024 - 10:12 PM
Cheers GraemeC! I take note of your advice.
#33 PACINO
PACINO
  • 741 posts
Posted 13 September 2024 - 10:29 PM
Try connecting the two breather canisters to the opposite carb breather ports. It doesn't matter about the lack of mesh in the timing chain cover breather at this stage.
Thanks for your help. So, as I understand your answer, to get 'positive' ventilation I should connect the breather next to the clutch cover to carburetor port and connect the breather from the timing chain cover to other carb port. Is this what you advise me?
Edited by PACINO, 13 September 2024 - 10:31 PM.
#34 Lplus
Lplus
  • 818 posts
Posted 14 September 2024 - 08:20 AM
That is what I would do to provide positive ventilation.  Crossing them over just makes for straightish pipes as opposed to having 180 degree bends if you connect the left breather to the left carb etc.  Make sure the oil filler cap is the breather type.  The idle mixture will go weaker so will need adjustment.
#35 PACINO
PACINO
  • 741 posts
Posted 14 September 2024 - 10:34 PM
Hi Lplus and thanks for reply. When you say "the only breather being the filter head on the transfer gear case", which breather are you referring to?
#36 Lplus
Lplus
  • 818 posts
Posted 15 September 2024 - 08:47 AM
I was referring to the red topped mesh filter at the bottom of your last photograph.  If you blocked the timing chain breather due to having no mesh then the red topped filter is on the only breather on the engine/gearbox.
#37 PACINO
PACINO
  • 741 posts
Posted 15 September 2024 - 02:23 PM
Oh yes! Now I understand you. Thanks a lot.
On the the timing cover breather I'll fit a red filter like the one I have on the other side, or when I get two rubber tubes, join both breathers to the carburetor ports as we already mentioned.
*Another option is to connect both respirators through a T, to the air filter box that I have at home. But I think you don't like this option.
#38 lsto
lsto
  • 577 posts
Posted 15 September 2024 - 04:26 PM
Just a word of caution. I fitted a cheap breather filter from ebay on my engine, after a few months my car started to leak oil and I was getting blue smoke from the exhaust. It turned out the breather had blocked solid and was pressurising the engine. I replaced it with a breather filter from k&n and it has been fine since (over a year now). Also the k&n is washable.
#39 Lplus
Lplus
  • 818 posts
Posted 15 September 2024 - 04:32 PM
For proper positive ventilation the only way will be to connect the breathers to the carbs.  Another red top filter will just reduce the crankcase pressure, but not below atmospheric pressure, so the problem may persist.  Connecting to the air filter box won't really help much either since there is minimal suction outside the filters - even if that little tube is drilled through to the inside.
#40 PACINO
PACINO
  • 741 posts
Posted 15 September 2024 - 05:01 PM
Cheers Isto for the advise. Of course, k&n are one of the best air filters.
With this one,I think should be ok too:
#41 68+86auto
68+86auto
  • 732 posts
  • Local Club: Queensland Mini Car Club
Posted 16 September 2024 - 05:19 AM
Just connect the breathers to the carbs and then you never need to think about it again. No valves or filters to go bad.
#42 ings
ings
  • 196 posts
Posted 16 September 2024 - 07:20 AM
What piston ring gaps you have on your fresh rebuild engine?
#43 PACINO
PACINO
  • 741 posts
Posted 16 September 2024 - 01:31 PM
#44 68+86auto
68+86auto
  • 732 posts
Posted 17 September 2024 - 12:11 AM
That's what you need.
#45 PACINO
PACINO
  • 741 posts
Posted 17 September 2024 - 05:56 AM
Swiftune Heritage Die Cast Piston
1275 +40
-High silicone hypereutectic alloy
-Forced Pin oiling
-6.5cc bowl
-2mm bowl offset
-38.05mm compression height
-59.65mm total length
-1.2mm NPR Japan steel nitrided top ring.
-1.2mm NPR Japan cast second ring
-4.0mm NPR Japan steel Nifflex oil ring.
-Running clearance 0.06mm (0.0025”)
-60.0mm x 20.638mm pin size (press fit pin).
-Case hardened pin to 57-65 HRC
-Circlip grooves for floating pin (pin optional).
