Leaking Oil
45 replies to this topic
#1 PACINO
PACINO
  • 741 posts
Posted 08 September 2024 - 09:44 AM
Hi everyone! I've got a big p. I've discovered that every time I use the car, a puddle of oil remains on the ground. Thinking that the leak could be from the rocker cover, I tightened both bolts. But the problem has not disappeared. The leak is big.
So thinking about this, there are two places where the oil could is leaking: - Timing chain cover.
- Differential shaft flange side cover. Around the lid or in the center, where the pot joint came in.
https://files.fm/u/6...xx5t?k=7a9f4211
#2 PeterG
PeterG
  • 30 posts
Posted 08 September 2024 - 02:59 PM
The oil cap on the rocker cover often leaks. Its a 12,000 mile replacement item. It took me a long time to find that one. Worth a replacement.
#3 KTS
KTS
  • 2,390 posts
Posted 08 September 2024 - 03:44 PM
if the diff output shafts were leaking i'd expect the puddle to be at the rear of the engine.
if the rocker cover gasket is leaking you should be able to it
the photo looks like ithe puddle is below the timing gear end, so start by looking for eevidence of leaks around the timing gear cover, crankshaft pulley seal or the half moon seal (tucked up behind the timing gear plate between the engine and gearbox)
#4 nicklouse
  • 18,366 posts
Posted 08 September 2024 - 04:00 PM
Get some UV oil dye and then you will know where the leak is rather than guessing.
#5 PACINO
PACINO
  • 741 posts
Posted 08 September 2024 - 10:33 PM
Thanks for reply Peter. Yes, I've seen some oil around the rocker cover filler neck. The cap is about 4 years old. I will change it, but it doesn't seem credible to me that so much oil could leak out there to form that puddle of oil on the floor, after using the car.
#6 Quinlan minor
Quinlan minor
  • 1,124 posts
  • Local Club: LSMOC
Posted 08 September 2024 - 11:05 PM
Basic question:
When was the rocker box gasket last replaced?
#7 68+86auto
68+86auto
  • 732 posts
  • Local Club: Queensland Mini Car Club
Posted 09 September 2024 - 12:24 AM
IF the oil is coming out of the rocker cover cap then you have an issue which isn't the cap - the breather system.
#8 nicklouse
  • 18,366 posts
Posted 09 September 2024 - 11:19 AM
Only as it is an air filter as well as an oil cap.
air is pulled through it as part of the breather system.
#9 PACINO
PACINO
  • 741 posts
Posted 09 September 2024 - 05:18 PM
Thank you very much for your help. It's all very surprising. The first few weeks of using the new engine, there were no oil leaks. Then it made a small puddle on the floor every day I used the car, and now it leaks a little oil, but less.
I'll check the engine every day, but is no easy to find it. Should be easier with the car on elevator.
Luis
#10 PACINO
PACINO
  • 741 posts
Basic question:
3 months ago.
#11 Quinlan minor
Quinlan minor
  • 1,124 posts
  • Local Club: LSMOC
Posted 09 September 2024 - 06:06 PM
Basic question:
3 months ago.
Check the hold-downs for tightness, but DO NOT overtighten them.
#12 PACINO
PACINO
  • 741 posts
Posted 09 September 2024 - 11:28 PM
Thanks Nick! I didn't know about this ultraviolet product to detect leaks.
#13 PACINO
PACINO
  • 741 posts
Posted 10 September 2024 - 12:02 AM
[quote name="68+86auto" post="3772456" timestamp="1725841494"
IF the oil is coming out of the rocker cover cap then you have an issue which isn't the cap - the breather system.[/quote]
I appreciate your response. The engine is newly built, it doesn't even have 300 km on it. My goodness, I hope I don't have that problem you mention with ventilation. I hope it is a leak from the timing chain cover or the rocker cover filler cap. The worrying thing is that we are not talking about a few simple drops of oil, we are talking about a larger amount.
Luis
#14 PACINO
PACINO
  • 741 posts
Posted 10 September 2024 - 12:03 AM
Hi everyone! Until now I couldn't upload all these photos to the Forum. In the first two pics we can see the oil stain left on the ground after driving the car. In the third, you can see the oil-stained pot joint of the drive shaft. In the fourth we see the lower part of the subframe, soaked in oil.
And in the last photo, we see oil "stains" on the rocker cover, around the filler neck.
#15 68+86auto
68+86auto
  • 732 posts
Posted 10 September 2024 - 12:07 AM
uote>
Luis
Please post some pictures of your engine bay to show all your hose connections etc.
