Hello all,
- I recently purchased all new wiring loom for my 1989 Mini Mayfair (YMC10654) as the old one was corroded badly (the car turned over with the old loom in), i believe that i have connected the loom up correctly (as i followed the correct wiring diagram on the forum) however the Mini won't turn over.
- I have bought and fitted a new +tve battery connection from the boot to the starter, a whole new set of HT leads and spark plugs plus a new coil. I don't need the car to start just to turn over.
- On the wiring diagram that i followed i noticed that on the starter relay there are two red/white wires that are connected to the relay and then one goes to the starter however this second wire does not appear on my loom (is this an extra wire i need to purchase?).
Also a another smaller query (do i need a ballast resistor for my car and is that the issue of it not turning over)
Many thanks,
- Matthew
