Things To Do With The Front Subframe Dropped
Posted 02 September 2024 - 11:25 AM
I'm planning on dropping the front subframe this winter to replace the mounts. I'm going to also remove the rad and flush the system and check the water pump. I also need to sort an advisory on the steering rack (nearside front play in steering rack inner joints).
I know that to change the mounts I only need to drop the subframe a little but is there anything else that I should consider checking/replacing while I'm at it?
Posted 02 September 2024 - 12:04 PM
The brake lines are the main limitation on dropping it clear. The body is more manageable than the front subframe for moving about.
Posted 02 September 2024 - 06:28 PM
May I suggest that you jack up the front of the car to remove both front wheels and then squat the gearbox securely.
Next, remove all the subframe bolts, pipes, wires, gear linkage, speedo cable etc:
Now jack the body off the subframe, or better, if you have a beam, lift it with pulleys until you can remove the steering rack.
Posted 03 September 2024 - 08:20 AM
Posted 03 September 2024 - 08:42 AM
Do I need to disconnect brake lines to get to the steering rack?
I disconnect the front brakes at the double female connector just above the cone turret to allow the subframe to drop without stressing the brake line, others may not bother. The rear brake line does not need touching at all as it runs between the rack and the bulkhead.
Posted 16 September 2024 - 11:01 PM
I've just been reading through the excellent guide https://www.theminif...ubframe-mounts/ but I can't find how the rear subframe mount is connected to the car? I can't picture how it goes together (and the photos don't load for me) can anyone help me out?
Mini spares lists this part (FRONT SUBFRAME REAR FIXING STRAP FLOOR TO MOUNT), where does this go?
https://www.minispar...ck to catalogue
Posted 17 September 2024 - 08:11 AM
It pokes through the floor from inside to help keep the bolts from turning when you undo the nuts securing the mounts.Steve.
Posted 17 September 2024 - 09:07 AM
I would just have a look but my footwells are covered in a sound deadening which I'll need to cut out first, but I thought there are nuts to undo from inside the car?
Posted 17 September 2024 - 09:22 AM
there are fixings from inside that hold the mount itself on the car
then there are fixings from that mount to the subframe, those ones are accesible all from outside/underneath and possibly for your purposes the easier ones to remove and refit
the mounts are kind of at a diagonal angle though so whether that will allow you to lower the frame I can't remember sorry, you'd have to have a look, or someone else will be along to correct me
Edited by stuart bowes, 17 September 2024 - 09:23 AM.
Posted 17 September 2024 - 03:46 PM
There are no nuts inside the car.the bolts are fixed to that strap and poke through the floor holding them captive.Steve..PS from the inside.
Posted 17 September 2024 - 04:21 PM
Thanks both. I need to replace the tower mounts so while I'm at it I may well end up changing the rear mounts too. At the moment I've a mixture of rubber and solid so I'll change if needed to go all solid.
I'll try and get under the car to check but it looks like I had better get that part and other new fixings and make sure everything is done right.
Plan currently is:
Check and change subframe mounts
Remover radiator/flush
Check water pump
Replace fan belt
Replace steering rack
(not in that order)
As suggested I'll aim to jack the body on a board rather than try and drop the engine
Posted 17 September 2024 - 07:16 PM
