Difficulties Starting - Coil Query
17 replies to this topic
#16 Lplus
Lplus
  • 785 posts
Posted 07 September 2024 - 07:19 PM
Thanks for confirming- can I bend it back? Or is it a new carb?
If the jet doesn't slide freely up into the carb base, it is bent.  You could try straightening it, but I'd go for a new jet.  You can get one which isn't the thermo type to give more clearace.
#17 68+86auto
68+86auto
  • 635 posts
  • Local Club: Queensland Mini Car Club
Posted 08 September 2024 - 12:11 PM
You just need a new jet (waxstat type for simplicity). They are a part which is meant to be relatively regularly replaced.
Edited by 68+86auto, 09 September 2024 - 12:29 AM.
#18 jacobtomos
jacobtomos
  • 78 posts
Posted 08 September 2024 - 06:58 PM
Thanks. I used some pliers to crudely straighten it out in situ and leaned the mixture out a lot and it spat a huge amount of black gunk out onto the drive and then ran quite smoothly. It has just run me about 3 miles and started straight after so I’m guessing I’ve found the issue! I’ll get a service kit and get it all sorted when I next get some time. Thank you all!
