Difficulties Starting - Coil Query
Posted 30 August 2024 - 03:44 PM
1988 mini randomly refused to start for me last week. Turns over strong, wouldnt fire. After usual fuel down carb/points checks etc I changed the plugs and it turned over straight away. The old plugs, though, were completely coked up- black, dry.
Drove to MOT today, then it started the same games! Bump started, got it back, spark plugs are black again. I’ve tried cleaning them up and it sounds like it wants to fire up but won’t. Turns over fast.
I’ve not had her long- it’s a ballasted system and I think the coil is non-ballasted. Would that have the impact of a weak spark?
Posted 30 August 2024 - 07:01 PM
Measure the coil and go from there. Might be a good opportunity to go through the ignition system and make sure everything is in good condition.
Posted 30 August 2024 - 08:10 PM
Posted 30 August 2024 - 09:04 PM
Posted 31 August 2024 - 01:54 AM
From thara you can start with the ignition knowing that the moxture is somewhere near. A strong blue sparh from each plug is requited for good running.
Posted 31 August 2024 - 10:26 AM
Posted 31 August 2024 - 11:43 AM
Have you measured the resistances yet?
Hope you get it sorted soon
Posted 31 August 2024 - 12:46 PM
Posted 31 August 2024 - 06:35 PM
Posted 02 September 2024 - 01:34 AM
Cheers, I’ll check the carb float then. I’ve checked the resistance and the current coil is giving around 2.8 ohm so I presume standard. I’ll get a ballasted one fitted and see how it goes.
Just make sure that the resistive wire hasn't been bypassed.
Edited by 68+86auto, 02 September 2024 - 01:35 AM.
Posted 02 September 2024 - 08:02 AM
Posted 02 September 2024 - 11:27 PM
I am worried about that. Is there a check I can do? The pink/white goes back into the loom and I assume somewhere connects back with the white as that is what is at fuse 1.
Fire it up and read the voltage between the coil positive and the engine/body earth.
Posted 07 September 2024 - 05:42 PM
Okay, so a few updates on this. New coil on (and now has MOT! ) but it only fires up once a day...
I get one journey out of each set of spark plugs. MOT station is about 5 miles away, so I got it there and then they needed to bump it to get it in. Also, once it was going for a few miles it just bogged down under load. Great at higher RPM.
I now know the coil is right and it is starting better (that once per day!). I did have a thought. When I first bought her the previous owner had removed the engine steady for whatever reason so every acceleration led to a clunk. Looking at the jet, it seems bent to me? There is also a mark on the bulkhead which seems to have been caused by the jet striking it.
Could the jet have been damaged, which is in turn causing the problems I'm seeing? Please can someone look at the pics and let me know your thoughts. If it is, what options do I have? New HS4?
Posted 07 September 2024 - 07:12 PM
Posted 07 September 2024 - 07:16 PM
