Pickup/van Petrol Tank Internal Pickup
35 replies to this topic
#16 KTS
KTS
  • 2,390 posts
Posted 28 August 2024 - 04:46 PM
it has an internal pipe to collect from the depression in the base of the tank
Thanks, is the collection pipe part available separately?
I couldn't see anything on Mini Spares diagrams.
I should remember all this but i refurbished the tank more than 5 years back.
photo (upside down!) of the internal arrangement - note that there is a gauze filter on the end of the collector pipe
did you use any kind of tank sealer when you refrubed the tank ?
#17 ac427
ac427
  • 669 posts
Posted 28 August 2024 - 10:52 PM
Thanks @KTS for the pic. It was so long ago, probably more like 8 years. I did not use any sealant.
It looks like the gauze filter is nylon rather than metal so i guess there is some hope of restoring fuel flow.
How did you clean up your tank?
Did you use a sealant in the end?
#18 68+86auto
68+86auto
  • 732 posts
  • Local Club: Queensland Mini Car Club
Posted 29 August 2024 - 12:57 AM
If you have a filter between your tank and pump you'll also be likely to encounter issues.
#19 KTS
KTS
  • 2,390 posts
Posted 29 August 2024 - 05:34 AM
the tank was cleaned up and repainted - nothing on the inside was touched
#20 ac427
ac427
  • 669 posts
Posted 29 August 2024 - 09:14 AM
Thank you. That's what I did. A new cork gasket for the sender etc.
It's a bit upsetting when the petrol comes through the sender screws. Some blue hylomar fixed that at the time though.
#21 ac427
ac427
  • 669 posts
Posted 29 August 2024 - 09:18 AM
I have one of the Proline (i think, the same as Mini Spares sell anyway) glass inline filters just after the tank outlet and before the pump.
It did look like brewed tea in there.
Once i disconnected the rubber pipe between the tank and the filter the old petrol drained out and the filter looked clean.
Sadly no petrol came out of the tank at this point.
#22 KTS
KTS
  • 2,390 posts
Posted 29 August 2024 - 04:39 PM
yep - mine leaked after the rebuild so replaced the blue hylomar with Permatex #2 on the gasket and it's not leaked since
#23 IronmanG
IronmanG
  • 1,212 posts
  • Local Club: Box hill. Lsmoc member
Posted 29 August 2024 - 05:10 PM
Yep same leak for mine. Quarter turn on all the screws seemed to fix it
#24 ac427
ac427
  • 669 posts
Posted 29 August 2024 - 08:32 PM
Thanks. I was just doing some research on Permatex 2 and I think Permatex or their holding company own Hylomar.
#25 ac427
ac427
  • 669 posts
Posted 01 September 2024 - 07:34 PM
I have removed the petrol tank from the Pickup out and drained the petrol from it.
I will get a new fitting kit but i was wondering how to actually replace the 3 nylon inserts that are under the load bed?
Is there a particular technique or knack to use to replace them?
Edited by ac427, 01 September 2024 - 07:34 PM.
#26 Lplus
Lplus
  • 818 posts
Posted 01 September 2024 - 07:46 PM
If you mean where the fixing screws screws screw into plastic downstands, they just clip in, so they can be prized out with a screwdriver.  ISTR that the screw expands them into the load bed for security.
these? http://minispares.co...px|Back to shop
Edited by Lplus, 01 September 2024 - 07:47 PM.
#27 ac427
ac427
  • 669 posts
Posted 01 September 2024 - 08:43 PM
Thanks. Yes, that is the one. I'll get the Mini Spares fixing kit because a couple of the screws look a bit rusty: http://minispares.co...04.aspx|Back to
Edited by ac427, 01 September 2024 - 08:43 PM.
#28 ac427
ac427
  • 669 posts
Has anyone used Bilt Hamber's Deox-C to revive a fuel tank?
#29 ac427
ac427
  • 669 posts
Posted 02 September 2024 - 08:32 PM
The pickup had grown tired of waiting to fixed up and decided to brew some tea in the meantime.  Thankfully it is just old petrol and not an indication of how bad the tank innards are. Once disconnected, a small amount of fuel drained out the filter looked clean
The petrol tank doesn't look too bad. Unfortunately i couldn't steer the endoscope past the baffle via the filler neck. I could have removed the sender of course but that would have delayed the cleaning solution phase.
I have filled the tank with Deox-C and will check the condition tomorrow.
#30 ac427
ac427
  • 669 posts
Posted 03 September 2024 - 08:52 PM
I had forgotten that there are only actually two nylon inserts needed for the shorter screws. The third is a captive nut type plate because of the proximity to the exhaust. I gave it a liberal spraying of Ferrosol.
Edited by ac427, 03 September 2024 - 09:51 PM.
