Door Woes
Best Answer 71bay , 01 September 2024 - 08:07 PM
Thanks all.
A shim fixed the problem.
Go to the full post
5 replies to this topic
#1 71bay
71bay
  • 62 posts
Posted 26 August 2024 - 09:19 AM
Hi , my drivers door does not line up with the striker plate.
When it is shut it is fine buy the striker plate forces it to be in the correct position.
How do I adjust the hinge ? just use a packing shim at the bottom hinge ?
Thanks Martin.
#2 Davidmt
Davidmt
  • 198 posts
Posted 26 August 2024 - 09:23 AM
Yes - you can use both shims on the hinges and also the striker plate can be moved to get the correct alignment.  If nececessary the frame can be persuaded into position too if it has been moved but hopefully not necessary and a combination of shims and movement in the striker plate will be fine?
#3 mab01uk
mab01uk
  • 12,387 posts
Posted 26 August 2024 - 03:42 PM
Minispares do a couple of different thickness door hinge shims for Mk3 on doors (see link below) or you can make your own:-
http://www.minispare...door shims.aspx
Or you may need to remove some factory fitted shims if you find any when removing the door.
Also beware of rust in the door hinge wheel arch area or rusted hinge studs making things a bigger/more difficult job than you planned!
Edited by mab01uk, 26 August 2024 - 03:46 PM.
#4 Aridgerunner
Aridgerunner
  • 96 posts
  • Local Club: None
Posted 30 August 2024 - 12:21 PM
Also, check your hinge pins. They too can be worn badly and cause this.
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,030 posts
  • Name: Neil
Posted 30 August 2024 - 12:32 PM
Yup, shims on the bottom hinge however as Aridgerunner has alluded to, if your hinge pins are worn then you want to consider changing the hinge. Pointless packing out with shims if the door keeps dropping as all it will do is increase the wear.
#6 71bay
71bay
  • 62 posts
Posted 01 September 2024 - 08:07 PM   Best Answer
Thanks all.
