I have had quite a bit of work done on my 998 gearbox, most recently fixing the synchro on 3rd gear. It was always quiet running but after the last round of work I notice that in 4th gear there is a definite whine on acceleration which goes when the throttle is lifted but returns on overrun. I am not sure if the noise is there with other gears as the car is a bit noisy. In the 'old days' I would have suspected the differential bearings were wearing, but is this likely with the mini? If so, what is needed to rectify it? The final drive was replaced by Guessworks about 2k miles ago with a 3.1 ratio unit.
Very grateful as always for any advice from the forum.
With best wishes
Mike
