Hif44 Carb Setup
3 replies to this topic
#1 REDICE
REDICE
  • 99 posts
Posted 25 August 2024 - 07:39 AM
Hi all
I'm nearly ready for first start.
I have what I have been told is a turbo hif44 and a turbo montego plenum.
What to check, what the 4 connections are, and the best way to set this up for base settings ie the mixture screw, needle, damper spring etc.
Its an eaton blow through setup. Any help much appreciated.
Attached File  20240825_192241 (1).jpg   49.38K   2 downloadsAttached File  20240825_192232 (1).jpg   53.92K   4 downloadsAttached File  20240808_110108 (2).jpg   71.79K   5 downloads
#2 lsto
lsto
  • 587 posts
Posted 25 August 2024 - 12:05 PM
Borrowed from turbo minis.
#3 lsto
lsto
  • 587 posts
Posted 25 August 2024 - 12:11 PM
Ignore 6,7 and 8 as they are for a NA 44. Personally if you are running any boosted set-up you'd be best of with a wideband gauge and then you can accurately set the idle fuelling and check the fuelling up the rev range then get a needle to suit.
#4 REDICE
REDICE
  • 99 posts
Posted 04 September 2024 - 06:12 AM
Thanks for the help people.
Saw Phil's awesome turbo hif you tube video - thanks you're a legend!
