Mini Mk2 Temperature Sensor Query
electrical
2 replies to this topic
#1 DavidHopkins
DavidHopkins
  • 19 posts
Posted 23 August 2024 - 09:56 PM
Evening all,
On my trusty Mk2 the CNH smiths gauge gives me a reading of the engine temp but I’d like to add a gauge for personal preference which details the degree temperature as well. Will the temperature sensor wired back to the voltage regulator allow me to split the connection to the current CNH gauge or will I require a new sensor in the thermostat housing to do so? I’m happy to do either but if it’s not possible by taking a feed from the existing gauge then I’ll change the thermostat housing and add a second sensor. Sorry if this seems like a daft question! Cheers
Edited by DavidHopkins, 23 August 2024 - 09:59 PM.
#2 Spider
  • 14,745 posts
Posted 24 August 2024 - 12:33 AM
If you want add another gauge, you'll need an additional sender, if however you wanted to swap it out for a numbered Smith Gauge, you can usually use the same sender.
#3 mab01uk
mab01uk
  • 12,370 posts
Posted 24 August 2024 - 08:25 AM
Alternatively you could fit a mechanical capillary type water temperature gauge which would be totally independent of the electric CNH gauge and sensor.
Smiths capillary gauge:-
https://www.minispar...ture gauge.aspx
WATER TEMPERATURE CAPILLARY TYPE GAUGE BY TIM:-
More on the advantages and disadvantages of each type in an old TMF thread here:-
Mechanical Or Electrical Water Temperature Gauge?
https://www.theminif...gauge/?p=893883
Edited by mab01uk, 24 August 2024 - 08:31 AM.
