Low Oil Pressure
21 replies to this topic
#16 gazza82
gazza82
  • 2,993 posts
  • Local Club: TMF+
Posted 07 September 2024 - 04:08 PM
Is the tube made of bronze like metal ?
No .. tinny stuff or plastic later
#17 Lplus
Lplus
  • 823 posts
Posted 07 September 2024 - 07:14 PM
there were flakes of bronze as well..caught amongst shavings of steel attached to sump plug magnet.
Or could it be from a washer or something in gear box
Seems more likely to be from the gearbox - my initial thought was a shaving from a worn selector fork. How big were the shavings of steel?
#18 mrmeds
mrmeds
  • 237 posts
Posted 07 September 2024 - 07:34 PM
well the pic is the palm of my hand - so the big bit is probably 3-4 mm wide and about  15-20 mm long
#19 Spider
  • 14,656 posts
Posted 07 September 2024 - 08:09 PM
It's possibly a remnant from the last time it was apart. I'd guess one of the the brass plugs that were drilled out of the Oil By-pass, pulled for cleaning.
#20 mrmeds
mrmeds
  • 237 posts
Posted 08 September 2024 - 10:28 AM
oil has been changed 5 times since rebuild - has around 4500 miles under its bonnet since
first 3 oil changes at  300,  660  and 1000 miles, then at around 4000 in april.
In fact may have been changed a 6 th time as have memories sourcing 20w/50 from local car factors.
Last oil change was last week a si could smell a slight whiff of petrol in it
Edited by mrmeds, 08 September 2024 - 10:34 AM.
#21 mrmeds
mrmeds
  • 237 posts
Posted 10 September 2024 - 07:03 PM
mini is nnow headed north to be looked at. The guy who picked it up said the bits looked like primary gear/ thrust washer .....
#22 mrmeds
mrmeds
  • 237 posts
Posted 18 November 2024 - 09:05 PM
its buggered ... main bearings , crank , just for starters
