Low Oil Pressure
21 replies to this topic
#1 mrmeds
mrmeds
  • 237 posts
Posted 23 August 2024 - 07:58 PM
I've got an oil leak I know about.. so when my oil warning light came on and I was getting less than 25 psi on the guage.. at idle of around 900-1000 rpm .. I wasn't surprised. I checked dipstick and yes it was just a tad below minimum.
Got some 20/50 oil to top up and put in about 750 ml....
which in hindsight was too much .. as I went out on a test and checked it... and it was about 5mm above mac on dipstick. all smmeded fine , until i went out on a 20 mile journey . Since then i've had problem with  low oil pressure when warm , at revs below 1500 !!!.
 Could my overfilling have forced by relief valve open and jammed it?
Only done 4750 miles since rebuild
Edited by mrmeds, 23 August 2024 - 08:07 PM.
#2 Avtovaz
Avtovaz
  • 1,199 posts
Posted 23 August 2024 - 08:12 PM
id draint he oil out of it and see if there is any metal in it, or take the filter off and cut it open to see.
#3 Spider
  • 14,656 posts
Posted 23 August 2024 - 08:27 PM
25 PSI at idle is fine. The norm is around 15 PSI.
The original switches were set at 7 PSI.
#4 imack
imack
  • 2,018 posts
Posted 24 August 2024 - 10:49 AM
Oil level just below minimum won't cause low oil pressure at idle.
If you have actually got low oil pressure it might be that the oil pressure relief valve has got stuck open due to debris, but it won't have anything to do with slightly overfilling the oil.
#5 mrmeds
mrmeds
  • 237 posts
Posted 24 August 2024 - 02:05 PM
whats the best way of unsticking ...just take it out  clean and put back in ?
#6 Steve220
Steve220
  • 4,990 posts
  • Local Club: BMC
Posted 24 August 2024 - 04:20 PM
Pretty much! Worth checking for evidence of it sticking open. I'd replace the oil pressure switch too, as it may not be reading correctly.
#7 mrmeds
mrmeds
  • 237 posts
Posted 24 August 2024 - 05:11 PM
best get a one inch spanner ... whichs seems like a challenge in itself lol !
#8 imack
imack
  • 2,018 posts
Posted 24 August 2024 - 05:40 PM
What was your oil pressure at hot idle prior to this issue?
#9 Cooperman
  • 23,199 posts
Posted 24 August 2024 - 10:53 PM
Overfilling by such a small amount won't cause any problems.
As above, it's most likely some 'DGS' on the relief valve. Just take the plunger out, clean and polish it, and all should be fine.
#10 mrmeds
mrmeds
  • 237 posts
Posted 26 August 2024 - 05:01 PM
about 40 I think, sometimes down to 25 if really hot
#11 mrmeds
mrmeds
  • 237 posts
Posted 03 September 2024 - 09:33 AM
ok now have carbs set up by a professional ! Overfueling sorted. He also loosened the cap to the pressure relief valve for me as he had a much longer spanner. !
 Will change oil later and see whats floating around in it
#12 mrmeds
mrmeds
  • 237 posts
Posted 03 September 2024 - 04:50 PM
weird , could'nt find any ball or valve cup ....
 drained oil bit did find..... guess thats my engined f@@@@@
#13 AllenCR
AllenCR
    Starting My Mini Up
  • 4 posts
Posted 06 September 2024 - 08:03 PM
Sorry.
Sure wish I knew what the hell that pic is!
"weird , could'nt find any ball or valve cup ...."
Sorry again, guessing that you've been looking under the big Relief Valve nut.
About the oil pressure, I haven't read anything about a problem, just     wild guessing for no apparent reason/s except a warning light switch that comes on too high.
"Could my overfilling have forced by relief valve open and jammed it?"
NO!
Assuming the gauge is somewhat accurate, it should at least be consistent and that's what really counts.
What PSI at idle cold, 3000rpm cold, idle hott, and 3000rpm hot??
15 idle hot & 45 3000 hot is fine, just not wonderful for a supposed professional rebuild, and if it wasn't for that trash I'd sleep soundly.
Good Luck.
Edited by AllenCR, 06 September 2024 - 08:21 PM.
#14 Earwax
Earwax
  • 473 posts
Posted 06 September 2024 - 11:07 PM
Sorry if this is a double post   -   not brass but could the detritus be from a dipstick tube ?
#15 mrmeds
mrmeds
  • 237 posts
Posted 07 September 2024 - 03:01 PM
there were flakes of bronze as well..caught amongst shavings of steel attached to sump plug magnet.
Is the tube made of bronze like metal ?
Or could it be from a washer or something in gear box
