Howdy Folks,
I finally got my feet wet in the mini world and became the proud owner of an '89 Mini not too long ago, I got the supplies for an oil change along with a replacement oil drain plug, but when I removed the plug I found it to be considerably larger than the replacement I purchased. Are there some mini's that come with larger plugs? The car was originally imported to the states from Germany if that makes a difference. Below I will include a link to an image of the two different plugs.
The replacement is from steveston motor co.
Thank you in advance for any input.
Respectfully,
Jesus
