Indicator Query Mk2
Posted 18 August 2024 - 05:52 PM
Posted 18 August 2024 - 07:31 PM
Well, The MK1 stalk does not have a horn function as it was in the wheel centre. For safety reasons, I discretely fitted hazard warning lights as the UK have this brilliant idea of doing away with a hard shoulder on motorways, so if your old car packs up, you could end up stuck in a live running lane with no warning for oncoming traffic. Anyway, I used the unused amber lights in the speedo for the hazard lights,
Posted 19 August 2024 - 08:19 AM
Is it possible to add an audible warning? Even the little light on the Mk 1 stalk is pretty insignificant.
Posted 19 August 2024 - 08:56 AM
You can get indicator relays that beep/buzz, often used on motorbikes. Have one in my car, much easier to notice when you haven't canceled the indicator!
Posted 19 August 2024 - 09:47 AM
The single green tell tale sits between the L & R circuits. When you indicate L it uses the R indicators as an earth & vicky verky. It's important the bulb bolder is isolated from the dash, but it does mean you can easily get separate L & R telltales by just run each wire via a warning lamp to earth.
Posted 19 August 2024 - 12:00 PM
On my Mk2 (RHD) I've used the two amber lights on the dial for left and right. Left is very obvious. Right tends to get blocked by the steering wheel - but that'll be different for everyone.
Edited by alpder, 19 August 2024 - 01:05 PM.
Posted 19 August 2024 - 07:18 PM
See 6 mins 33 secs on this video
Edited by floormanager, 19 August 2024 - 07:18 PM.
Posted 20 August 2024 - 06:42 AM
Posted 21 August 2024 - 10:45 AM
Not sure about the buzzer, but the video is excellent.
Both style & content
Posted 22 August 2024 - 08:22 AM
Excellent video, with so many people converting to LED it should be pined to the Tech section.
