Late Model Dash Top ....
4 replies to this topic
#1 Bobbins
Bobbins
  • 1,464 posts
Posted 13 August 2024 - 10:13 AM
When I stripped my '98 I removed the windscreen before the "dash panel upper padded rail", but can the rail be refitted after the windscreen has been fitted? I seem to recall it needing to go upwards/forwards to remove which would be difficult with the glass in place.
#2 Midas Mk1
Midas Mk1
  • 5,749 posts
  • Local Club: S.U.N.M.C
Posted 13 August 2024 - 11:02 AM
It's very tight, can be done, but ideally windscreen after if it's not already fitted.
#3 Chris1275gt
Chris1275gt
  • 890 posts
Posted 13 August 2024 - 12:44 PM
I needed to take mine out with the windscreen in and got it out in the end putting it back I shortened the studs on the dash rail a bit and it went back in relatively easy. I would presume the later ones would be virtually the same.
Edited by Chris1275gt, 13 August 2024 - 12:46 PM.
#4 stoneface
stoneface
  • 358 posts
Posted 13 August 2024 - 01:10 PM
Did the same, shortened the studs.
#5 Bobbins
Bobbins
  • 1,464 posts
Posted 13 August 2024 - 07:45 PM
Thanks all. I’ll investigate shortening the studs because I’d prefer to get the screen in soon.
