Valve Lash Adjustment
7 replies to this topic
#1 croc7
croc7
  • 801 posts
Posted 10 August 2024 - 12:46 AM
I'm curious to know the popular method used to rotate the engine when adjusting valves.  Plugs in or plugs out?  Turn over the engine using a remote starter or car in 4th gear and move car to open valves?
#2 Spider
  • 14,613 posts
Posted 10 August 2024 - 02:40 AM
Hey Jerry !
I think all those methods and more work. I've just put the car in 3rd or 4th and pushed it about. I've tried using the starter motor long time ago and found that fraught with frustration.
#3 GraemeC
GraemeC
  • 7,418 posts
Posted 10 August 2024 - 06:27 AM
My two favourites:
Plugs out, fan belt tight and a 24mm ratchet spanner on the alternator pulley nut
Or
Plugs out, in 4th with just one front wheel on the ground turn opposite wheel by hand or with a socket on the CV nut (wheel and split pin removed)
Edited by GraemeC, 11 August 2024 - 08:25 PM.
#4 Chris1275gt
Chris1275gt
  • 890 posts
Posted 10 August 2024 - 07:17 AM
I do the wheel off the ground and turn the wheel looking across the engine you get a good view of the valves to see when your next one is closed.
#5 cal844
cal844
  • 9,601 posts
  • Local Club: TFMOC
Posted 10 August 2024 - 11:38 AM
I just put the car in 4th and rock it back and forward as needed, with the plugs out it's alot easier
#6 Earwax
Earwax
  • 467 posts
Posted 10 August 2024 - 11:35 PM
If you are using the rule of 9s and setting 8 individual times you need a longer runway than if you do with valves rocking  :shifty:
#7 Lplus
Lplus
  • 818 posts
Posted 11 August 2024 - 08:26 AM
This - a scissor jack under the tie rod nut and lift the wheel just off the gound.  Place in 4th gear - remove plugs.  Even then the whole lot takes a bit of effort to shift, not surprising given the various bits that have to be turned.
#8 Midas Mk1
Midas Mk1
  • 5,749 posts
  • Local Club: S.U.N.M.C
Posted 11 August 2024 - 05:48 PM
My two favourites:
Or
Plugs out, in 4th with just one front wheel off the ground turn opposite wheel by hand or with a socket on the CV nut (wheel and split pin removed)
Thanks for this, tried your method yesterday morning using the cv nut, with my ball joint droppers and lowered shocks struggle with droop when jacking up one side, normally lifting the NSF too/ The hub nut method is a smooth and effective option, would recommend!
