Hs4 Carb Needle Or Wait For Hif44 On A Stage 1 1275?
engine
Best Answer cal844 , 06 August 2024 - 03:18 PM
I'd just change the needle on the hs4, pointless going to a HIF for little gains Go to the full post
3 replies to this topic
#1 Suburu
Suburu
    Just On Tickover
  • 8 posts
Posted 06 August 2024 - 02:24 PM
Hi all,
I'm soon to be running my 1275 motor with a K&N air filter element in the standard box (drilled) and maniflow 13/4 RCM road centre exit exhaust (I like the look haha).
Currently there is a single HS4 fitted and I have been eyeing up HIF44's/ HS6's. I won't be going further than stage 1 for the foreseeable (he says) so I was wondering if it is worth getting the bigger carb or instead just changing the needle on the HS4 ?
It's my only car, so it is run often. I'm trying to assess the cost benefit impact to my mpg vs performance (although that probably wouldn't stop me).
#2 cal844
cal844
  • 9,610 posts
  • Local Club: TFMOC
Posted 06 August 2024 - 03:18 PM   Best Answer
#3 kiwi topcat
kiwi topcat
  • 33 posts
Posted 07 August 2024 - 06:11 AM
i have recently removed my HS4 and installed a HIF44
the difference was vastly improved as one would expect when going from a 1.5 to 1.75 diameter carb
change to HIF 44 is the way to go
#4 timmy850
timmy850
  • 3,262 posts
  • Local Club: MITG
Posted 07 August 2024 - 07:51 AM
It does also depend on:
Condition of your HS4
Is the current HS4 needle appropriate?
Is your stage 1 HS4 needle appropriate?
Unless you can measure the air fuel ratio in the exhaust you'll be completely guessing if it's running right or not.
If you get a different carb, it really needs to be rebuilt to as-new and set up by an expert so that the mixture is correct across the RPM and load range.
