Fuel Tank
Posted 04 August 2024 - 02:01 PM
Not in car if helps
Posted 04 August 2024 - 03:34 PM
I don't know the best way. I blasted mine out with a hosepipe and lots of water several times until the water came out looking reasonably clean, and then fitted an inline fuel filter.
Posted 04 August 2024 - 04:36 PM
I`ve done gunky motorcycle tanks with caustic soda and then finished off with citric acid which is the same stuff you pay four times as much for at Bilt Hamber
Look it up on ebay it`s used for bath bombs.
Posted 04 August 2024 - 04:44 PM
Shooter
Posted 04 August 2024 - 05:54 PM
Posted 04 August 2024 - 08:05 PM
Posted 04 August 2024 - 09:45 PM
when I did mine I bought 10 litres of white vinegar, after sealing the tank I put the lot in then left it for a couple of weeks turning the tank everyday. Worked perfectly, though I did add a bicarbonate of soda solution after to neutralize the acetic acid in the vinegar. Then I blasted the tank out with a pressure washer then dried the inside immediately with the aid of a heat gun, if you don't dry it out straight away it will flash over with rust very quickly.
Forgot to add I used the vinegar because the tank was more rusty than dirty
Edited by Stu1961, 04 August 2024 - 09:49 PM.
Posted 05 August 2024 - 04:33 AM
Posted 05 August 2024 - 04:36 AM
