Is It Easy To Swap Post 84 Drums To Pre 84 Drums?
brakes
6 replies to this topic
#1 Daniel Watkin
Daniel Watkin
  • 11 posts
Posted 03 August 2024 - 10:53 PM
Hey,
So to put it briefly, my ET14 wheels stick of the rear arches. I have a 1992 car with rear drums which have the 1 inch spacer built in to the brake drum, as with all post 1984 Minis. Is it an easy job to just bolt on a set of pre-84 drums without the spacer? I'm happy to do the work, just need to know whether the parts are compatible before I buy?
Many thanks
Dan
#2 nicklouse
  • 18,569 posts
Posted 03 August 2024 - 11:35 PM
You will need shorter wheel studs.
have you looked at the front as you are on discs they will stick out just as much on the front.
#3 Spider
  • 14,832 posts
Posted 03 August 2024 - 11:36 PM
Nice !
Yes, fairly easy job, though, you'll need to change the wheel studs. To get the long studs out, you will need to remove the Hubs or if you wanted to be a butcher, drill a hole in the brake backing plate to allow the stud to be swung clear of the back of the hub.
Just be sure not to get any dirt or crap in the wheel bearings.
#4 mab01uk
mab01uk
  • 12,409 posts
Posted 04 August 2024 - 08:28 AM
As said if you have disc brakes at the front (1992 Mini) and you swap to non-spacer rear drums your track at the rear will be narrower than at the front which will look odd and may affect handling....assuming you are using the same wheels with ET14 offset front and back.
Alternatively you could try pre'84 drums with narrower separate alloy spacers or fit wider wheel arch extensions.
Minispares wheel spacers:-
http://www.minispare...ers.aspx?200104
Edited by mab01uk, 04 August 2024 - 08:33 AM.
#5 weef
weef
  • 489 posts
Posted 04 August 2024 - 12:05 PM
I cannot remember if the standard short studs will fit with the hub in place but if they do you can always cut the long studs short enough to punch the remainder out. Fit the new studs and pull them in snug.
#6 Pete649
Pete649
  • 375 posts
Posted 04 August 2024 - 03:57 PM
From memory they do, just.
#7 coopertaz
coopertaz
  • 791 posts
  • Local Club: a-series-magpies
Posted 05 August 2024 - 10:16 AM
Hey,
Many thanks
Dan
confused here as asked above do the fronts not also stick out of the arches?!
Also tagged with one or more of these keywords: brakes
