Does anyone have a definitive measurement of the spacing.
From a drawing rather than measured.
i have some measured figures but wonder what the real measurement is.
Posted 31 July 2024 - 08:44 AM
Posted 31 July 2024 - 09:00 AM
Centre to Centre the Towers are 30-1/4" +/- 0.010"
If it's a Single Bolt, that's the bolt centres. If it's a Twin Stud, they are 1-1/2" either side of that also +/- 0.010"
Posted 31 July 2024 - 09:03 AM
Cool that was the measured figure I had just wanting to check.
Posted 02 August 2024 - 02:11 PM
So I actually have an MTB subframe and I am doing take a look at fittings to make sure my construct comes together properly. The guide would not explicitly communicate approximately what bush to use between the pinnacle of the subframe and the firewall box.
Edited by alkiao, 03 August 2024 - 09:53 PM.
Posted 02 August 2024 - 02:22 PM
you have the option of rubber or solid
rubber - https://www.ebay.co....:Bk9SR6i6qreiZA the diamond shape goes on the subframe (below the crossmember) and the round one goes on top (below the bolt head)
solid versions are available and often preferred, I assume that would still be the case even with the different engine and subframe https://www.minispar...0.aspx|Back to the ones with flat edges go on top to clear the triangular support brackets, the fully round ones go underneath
I don't know the bottom fixings are solid ? if so I'm guessing you'd also want solid ones up top
(not from 1st hand experience just supplying the links for reference purposes)
Edited by stuart bowes, 02 August 2024 - 02:26 PM.
Posted 02 August 2024 - 02:55 PM
You must go either all-solid or all rubber. Never use the poly-bushes/mountings for reasons explained on here many times.
