Headlights Not Working 1994 Rover Mini
Best Answer Ethel , 29 July 2024 - 08:20 PM
So you've lost dip & main beam on both sides?
Do the tail & sidelights still work, with the headlights turned on?
Do the headlight flasher & horn work?
Go to the full post
15 replies to this topic
#1 Sugarbear6
Sugarbear6
  • 13 posts
Posted 29 July 2024 - 05:32 PM
All the front lights went out.   I've changed the headlight switch, the turn signal/flasher switch, wiper switch.  I've also cleaned all the front light ground wire terminals and replaced the connecting blocks.  The rear lights are working fine.  I've checked the 4 fuse block on the firewall.
I'm open to any suggestions.
#2 lsto
lsto
  • 587 posts
Posted 29 July 2024 - 05:58 PM
If you follow the loom from the headlights back you will come across some bullet type connectors which can corrode. More likely there is a big pink relay just below the Speedo behind the dash that can fail.
#3 beardylondon
beardylondon
  • 1,506 posts
Posted 29 July 2024 - 07:00 PM
On my 1990 Cooper I had the same issue, and the culprit was the fusebox. However you could only see the issue from the rear of the fusebox, by unscrewing it from the bulkhead. All the metal connectors had rusted so I replaced the fusebox with a new one and it rectified the issue.
#4 Sugarbear6
Sugarbear6
  • 13 posts
Posted 29 July 2024 - 07:51 PM
I replaced the fuse block a couple years ago.  All fuses are in good shape.
But,  Thanks for the input.
#5 Ethel
  • 25,893 posts
Posted 29 July 2024 - 08:20 PM   Best Answer
#6 cal844
cal844
  • 9,617 posts
  • Local Club: TFMOC
Posted 30 July 2024 - 05:56 AM
Have a look up behind the dashboard binnacle, there may be 4 in line fuses for dip beam and main beam (there is on my 1993 sprite carb car) my car has the 4 fuse box on the bulkhead.
#7 andyapanel
andyapanel
  • 620 posts
Posted 30 July 2024 - 06:37 AM
You might have a look at the multiplug that serves the light switch
They can fail due to high current if you have no relays in place, but I would still check those earths. Try bridging across the earth bullet connector to the body.
Good luck
#8 Ethel
  • 25,893 posts
Posted 30 July 2024 - 10:50 AM
The only place high 'n low, L&R share the circuit is the output from rocker switch to input to the stalk (blue wire). The headlight flasher uses a different supply, so it works without the lights on. If it works it makes rocker switch to stalk more likely.
#9 Sugarbear6
Sugarbear6
  • 13 posts
Posted 30 July 2024 - 02:53 PM
I don't have any front lights or front sidelights.  Rear lights work ok.  Headlight flasher don't work.  haven't tried horn.
#10 sonscar
sonscar
  • 2,982 posts
Posted 30 July 2024 - 03:06 PM
You have possibly lost the earth behind the grille(or wherever the lights all earth to on your car)or the earth point on the bulkhead triangle on the sitting in the car.Get a tester and stop guessing.Steve..
#11 Ethel
  • 25,893 posts
Posted 30 July 2024 - 03:33 PM
With all that out I'd suspect the earth. That's the black wires screwed to the body.
#12 Sugarbear6
Sugarbear6
  • 13 posts
Posted 30 July 2024 - 03:53 PM
I'll Check that.
#13 Ethel
  • 25,893 posts
Posted 30 July 2024 - 04:13 PM
I'll Check that.
That would be quite a combination of blown fuses, there's 4 - one for each filament. It also wouldn't explain the sidelights as they're on the same fuse as the tail lights.
#14 cal844
cal844
  • 9,617 posts
  • Local Club: TFMOC
Posted 30 July 2024 - 06:12 PM
I'll Check that.
I always try to do the free checks first (unless diagnosed as a paying fix) , even to back probe and test for voltage at the fuses.
#15 Sugarbear6
Sugarbear6
  • 13 posts
Posted 31 July 2024 - 03:11 PM
I'll Check that.
Checked the 4 fuses.  They're all good.
