Smoke Pouring From Oil Fill
Posted 23 July 2024 - 02:26 AM
Posted 23 July 2024 - 08:44 AM
Just my opinion -
What is the mileage on this engine , and what work done on it previously ?
are you using breather to carb - or open to atmosphere , are pipes & breather clear?
Do a compression check before pulling the head
no plugs in with throttle open , charged battery , dry , then put some oil down bore , record pressures .
also check head torque settings - look for one a bit looser than the rest
look for oil on the plugs
sounds like a piston ring may have gone or picked up in the bore
but there are loads of other things it could be
cheapest is a fire ring gone thru to oil return hole on head gasket , or breathers blocked
most £xpensive is a rebore & pistons / rings
hope it's cheap to fix
others will be along with more idea's ,
best of luck
Edited by sledgehammer, 23 July 2024 - 08:46 AM.
Posted 23 July 2024 - 08:52 AM
It does sound like a broken piston ring or rings. I note that you say smoke is 'pouring' from the oil filler cap, which indicates more than just a bit of bore/ring wear.
It could be a head gasket, in which case you would be lucky, but that seems a bit unlikely.
I had a 1990 Cooper which I bought for restoration a while back and the engine was smoking and using a bit of oil. That turned out to be two broken piston rings, but the smoke was not 'pouring' out of the filler cap. It could, of course, be a damaged piston.
I think you will end up pulling the engine out and stripping it right down for a proper look.
Posted 23 July 2024 - 02:47 PM
Posted 23 July 2024 - 03:04 PM
is it smoke or water vapour ?
Posted 24 July 2024 - 04:27 AM
Great great question. Looked like smoke but let me get a wiff of it next time I fire her up.
Posted 27 July 2024 - 07:52 PM
Posted 27 July 2024 - 10:06 PM
Edited by Zlevin23, 27 July 2024 - 10:25 PM.
Posted 28 July 2024 - 05:19 AM
If the head gasket is blown into the pushrod holes it'll be pushing a lot of pressure through the crankcase/rocker cover
Posted 05 August 2024 - 02:17 PM
Any update on this ?
Hope it was cheap
Posted 07 August 2024 - 12:40 PM
whenever ive had head gaskets fail it's always between 2 and 3 check block and head for any damage here if this has blown through had it knacker an old engine when i had to limp it home with this blown
