Iacv With Sc Throttle Body
13 replies to this topic
#1 EuphoriX
EuphoriX
    Just On Tickover
  • 8 posts
Posted 22 July 2024 - 06:14 PM
I have a UMS running a SC throttle body on my SPI
Have done some 3D printing to add a sandwich plate to take an IACV
The MPI IACV has the same socket as the SPi stepper motor
Has any one ever run an IACV on a spi men’s unit or similar
Just need to manage the warmup - idle is fine without
(This is just a project to see if can be done without going to a full blown mega squirt or other big boys ECU’s)
Thank you.
#2 Steve220
Steve220
  • 5,032 posts
  • Local Club: BMC
Posted 22 July 2024 - 06:53 PM
It has been done, you'll need to pin your ecu for it, I THINK you need a 2 pin iacv motor, but worth checking with SC first.
This was my biggest gripe with the system, and typically sc didn't like thenfeedback and gave some tosh about them being fine with ignition idle control from cold. I ditched the lot and went DBW and haltech elite ecu.
#3 tmsmini
tmsmini
  • 727 posts
  • Local Club: MOASF
Posted 24 July 2024 - 03:59 PM
If you are using UMS, then it is more a matter of what UMS supports. There are unipolar and bipolar valves. There is a Bosch version that is two pin, used on volvos I think.
#4 EuphoriX
EuphoriX
    Just On Tickover
  • 8 posts
Posted 24 July 2024 - 06:14 PM
The UMS is unipolar and want to “dovetail” into this if I can.
Currently looking at 3d printing an alternative housing for the stepper motor to operate a valve
Any circuit diagrams or pin-out/wiring info would be useful as I am keen to try and convert to use a valve instead of the throttle adjustment.
Not sure SC would have much interest to using their throttle body with another’s ECU
That said running a 276 cam with big valve head and once warm the UMS idles very nicely at 850rpm and pulls away nicely too
Edited by EuphoriX, 24 July 2024 - 06:17 PM.
#5 tmsmini
tmsmini
  • 727 posts
  • Local Club: MOASF
Posted 24 July 2024 - 07:03 PM
This is the Bosch version. I never used it as I planned. The plan was to use Megasquirt on the MPi manifold. These would be mounted remotely and an adapter to the manifold would need to be made. In the USA, DIY Autotune also had a remote style IACV available at one time.
My skills to fabricate the adapter are lacking. For wiring, you might visit the Megasquirt documentation and forums and see if you can translate it to UMS.
#6 EuphoriX
EuphoriX
    Just On Tickover
  • 8 posts
Posted 27 July 2024 - 08:56 AM
Update: so the MPI is a direct plugin for the SPI stepper - only issue is the coil resistances are much smaller (6ohm) the secondhand IACV I foolishly did not measure and had two coils which were shorts - this burnt out the tracks on the UMS pcb.
Have now mended the PCB and tested with both SPI and MPI steppers - both operate in the same direction.
To limit the current have added a 8.2 ohm resistor in the 12v supply and the MPI stepper still operates happily.
I have not started the engine as yet as there are a few other things I need to attend to - but it looks like using a MPI IACV will do the job
And I can remove the manual value I have at the moment
Edited by EuphoriX, 27 July 2024 - 03:32 PM.
#7 EuphoriX
EuphoriX
    Just On Tickover
  • 8 posts
Posted 27 July 2024 - 03:33 PM
Update - started fine and works as expected - just need to now tune the warmup
#8 brivinci
brivinci
  • 1,161 posts
Posted 29 July 2024 - 06:04 PM
Man!! You guys are like wizards when it comes to this!! I have toyed with updating my standard SPi system for something tunable....but clearly would be lost before I got started! Very clever things you all are working through.
#9 sonscar
sonscar
  • 2,983 posts
Posted 29 July 2024 - 07:48 PM
I think you would find it less challenging than you think.My concern is you would be paying handsomely for a system and only using its most basic functions.Have a go,you may find it rewarding.Steve..
#10 tmsmini
tmsmini
  • 727 posts
  • Local Club: MOASF
Posted 30 July 2024 - 08:01 PM
Would you be willing to make others to sell or share the file used to create the adapter? Did you also custom make something for the intake end of the throttle body?
#11 EuphoriX
EuphoriX
    Just On Tickover
  • 8 posts
Posted 31 March 2025 - 05:00 PM
Been a while - apologies
More than happy to share the stl file - 3d printed in china in aluminum - for less than £80 delivered
I also am looking to sell my UMS as have decided to go down the Haltech route
#12 tmsmini
tmsmini
  • 727 posts
  • Local Club: MOASF
Posted 01 April 2025 - 04:09 PM
I am still interested in the STL file. I have a spare engine in a stand that I would like to try some haltech variations on. It would mean buying a haltech though.
#13 EuphoriX
EuphoriX
    Just On Tickover
  • 8 posts
Posted 02 April 2025 - 07:10 PM
There are two - one for an MPI stepper - which will work with a UMS - needs a resistor in the 12v wire (circa 8ohm, 50w) - need to check the pin orders - I had to swap mine - but it worked
I switched to a speedunio from RM Racing Electronics (really helpful and nice piece of kit) - but I have struggled with the software and the inability to fine tune (only integers) and also coming off throttle and stalling - as there is no dashpot setting to catch the RPM
I switched to a PWM IACV (and wasted spark) - much much better - smoother idle - but still the same issue - which is also linked to the rate of RPM decline due to the lightened flywheel.
The real key to the idle is in the voltage correction and deadtime for the injectors - took a while to nail.
You will need to rename the stl's - removing the ".txt"
Developed using "https://www.tinkercad.com"
I used "https://craftcloud3d.com" to get these fabricated
The v2 spacer is more generic - for Idle Air Control Valve IAC1057 For Ford Lincoln Mercury 2003-2006 | eBay its a little "big", in that its for a far bigger engine and the PID values need to be very small - but it works well
#14 tmsmini
tmsmini
  • 727 posts
  • Local Club: MOASF
Posted 02 April 2025 - 09:53 PM
Thank you
