I have a 1998 mini Mayfair with a 1275cc metro engine in it. I be replace the master and slave cylinder and bled it throughly with no air or leaks coming out of it. I need a local garage near Brighton to help resolve my issues. Can anyone recommend a specialist near me that can help.
Matthew
1998 Mini Clutch Issues
matthewwadsworth
, Jul 18 2024 11:40 AM
2 replies to this topic
Posted 18 July 2024 - 11:40 AM
Posted 19 July 2024 - 07:48 AM
What is the problem?
Posted 21 July 2024 - 05:13 AM
Go back and think methodically.
If you are getting fluid movement from master and slave, then the fault lies with the clutch plate, release bearing or infact the flywheel.
Let's us know what issues you are facing? What you have done? What happened before or why you changed master and slave.
Is pedal box pin all in order?
Clutch throw out on bell housing free and moving?
So many possible options..
Sure we will assist YOU to get it fixed..
Edited by bpirie1000, 24 July 2024 - 07:10 AM.
