Posted 18 July 2024 - 03:59 AM
I just acquired a set of original 10x5 Dunlop D1 wheels. Im planning to put them on my 1964 van.
Currently on all 4 drum brakes.
My question(s)
what lug nuts are needed for the wheel to fit. Im guessing they’ll be sleeved?
Any info, thoughts or suggestions appreciated.
Posted 18 July 2024 - 09:32 AM
http://www.speedshac...k/Wheelnuts.htm
Posted 18 July 2024 - 11:16 AM
Yes you are right the are a sleeved wheel nut with a washer. . They are available on Ebay as well
Posted 22 July 2024 - 11:05 PM
Posted 23 July 2024 - 08:56 AM
From Memory, I think the wheel nuts as used on the original pattern Minilites, which are sleeved, fit if the chamfered washer is turned the other way around (i.e. chamfer to the outside).
Posted 23 July 2024 - 01:54 PM
Yep you remember correct :) These fit I believe C-21A1969 - Mini wheel nut stainless for minispares wheel includes washer
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Tall Nut Attached Left Front Brake Hose To SubframeStarted by dschwartz1957 , Yesterday, 05:50 PM ![]() |
![]() Handbrake Plate And Sealing PadStarted by dschwartz1957 , 22 Apr 2025 ![]() |
Brake Servo And Lack Of Brake PedalStarted by Moose94 , 14 Mar 2025 ![]() |
Brake Lights Stopped WorkingStarted by joobs1986 , 04 Dec 2024 ![]() |
![]() Installing Front Brake Shoe Retainer Springs (27H3753)Started by dschwartz1957 , 08 Nov 2024 ![]() |
