Hi
I have an 89 998 with a grey cap on the brake cylinder reservoir with terminal opposite each other.
One has corroded away and I wonder if the caps for sale with what looks like two terminals on the same side are a direct replacement?
This is the product I have seen
http://minispares.co...k%20to%20search
4 replies to this topic
Posted 15 July 2024 - 05:56 PM
Posted 15 July 2024 - 06:26 PM
According to the blurb on the Mini Spares webpage, yes.
Posted 16 July 2024 - 09:44 AM
They are direct replacement, you will need to change the plug terminals to allow fitment of the new cap
Posted 17 July 2024 - 08:46 AM
Thanks, hopefully the terminals are a known standard part?
Posted 17 July 2024 - 09:40 AM
6.3mm crimp on spades fit, the original Lucas connections may fit but mine didn't.
Also tagged with one or more of these keywords: brakes, electrical
Mini Technical Sections →
Problems, Questions and Technical →
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
