Mini Wheel Nuts Required
Best Answer KenM , 25 July 2024 - 10:22 AM
I believe my problem is resolved whereby the inserts are mostl likely for original mini 5/8 unf radius nuts but being relatively soft brass or similar, they have deformed over time by previously having a series on incorrect nuts fitted.  Anyway the new nuts seem to fit quite nicely wheels are secure centralized and thre nuts will almost certainly bed in over time.
Thanks to 'all' who assisted here on the forum and thanks to Tim of Raceways, great guy and company to deal with and after helping identify what was needed the nuts arrived the next day, excellent help all round gents thanks again - Ken
Go to the full post
16 replies to this topic
#1 KenM
KenM
  • 12 posts
Posted 15 July 2024 - 07:47 AM
Hi there
I have a Mini with what I think are Italian Innocenti wheels (10"), the problem is that although the studs are 5/8 UNF it seems the correct taper for the nut is 45 degreees and not the more common 60 degrees?  Does anyone have or know where I can get the 3/8" UNF with the 45 degree taper please?  Thanks in advance - Ken
#2 nicklouse
  • 18,586 posts
Posted 15 July 2024 - 04:28 PM
Pictures of the wheels? Any numbers/names on them?
#3 KenM
KenM
  • 12 posts
Posted 16 July 2024 - 10:13 AM
Hi @nicklouse, No names or numbers that I can see, and with regard pics, I tried to uploiad pics but for some reason the site doesnt seem to allow me to do it either as a posted snapshot or to attach a Jpeg file, only to choose a file but not to attach it once chosen, any ideas?
#4 Ethel
  • 25,935 posts
Posted 16 July 2024 - 11:37 AM
Our server would grind to a halt if it hosted all the piccies. It's best to upload them to something like Imgur and  embed from there.
https://www.theminif...-upload-images/
#5 john2502
john2502
  • 115 posts
Posted 16 July 2024 - 12:39 PM
Or resize them down so small they'll upload.
My phone camera's pictures come out 1-2MB directly, using MS paint to quickly resize them down to 20% size then put them about 100-200KB which is fine for uploading here and more than enough resolution to see.
#6 KenM
KenM
  • 12 posts
Posted 16 July 2024 - 04:42 PM
Attached File  small small IMG_4788.jpg   18.7K   11 downloadsAttached File  small small IMG_4787.jpg   25.09K   12 downloadsAttached File  small small IMG_4789.jpg   17.65K   8 downloads
Trying again with tiny files per advice
#7 KenM
KenM
  • 12 posts
Posted 16 July 2024 - 04:44 PM
Hi Nicklouse, no markings on the wheels that I can see unfortunately
#8 Shooter63
Shooter63
  • 1,030 posts
Posted 16 July 2024 - 05:02 PM
Try phoning Minispares, your wheel nuts look like the sleeved type, they sell that type which come with a separate washer, the angle may be correct, or at least you could use the nuts and get some new washers made, but take dimensions before phoning them, to make sure things will fit.
Shooter
#9 nicklouse
  • 18,586 posts
Posted 16 July 2024 - 05:08 PM
Ahh Momo/fondmetal wheels.
use Imgur to host your pics full-size and use their forum link.
https://www.classicm...echnical/wheels
Might help you check which wheels they are.
put your pics on Imgur and I will look later not sure of the accuracy of your paper.
#10 KenM
KenM
  • 12 posts
Posted 21 July 2024 - 09:17 AM
Hi Nicklouse, yes I reckon Momo, will do some more searching for details, thanks!
#11 KenM
KenM
  • 12 posts
Posted 21 July 2024 - 09:26 AM
https://imgur.com/a/08GLlU9
Does this work?
#12 nicklouse
  • 18,586 posts
Posted 21 July 2024 - 02:54 PM
Pic of the back? I recon it has inserts and they have been run on lists of different nuts.
i would swap the inserts over.
Like https://www.raceways...eel_inserts.htm
#13 smurfomatic
smurfomatic
  • 460 posts
Posted 21 July 2024 - 04:52 PM
I used raceways a couple of years ago for new inserts and wheel nuts - very good service
#14 KenM
KenM
  • 12 posts
Posted 21 July 2024 - 07:58 PM
Hi Nicklouse, I reckon you are spot on, scraped the paint of the back of one bolt hole and think its a brass insert and some have definitely got a range of indentations from different nuts.  Do the inserts just tap out from the back?  If so I will take one out and see if I can get direct replacemnt inserts but with the 60 degree taper i.e. the same OD as the original insert.  Thanks for the continuing advice, greatly appreciated!
#15 nicklouse
  • 18,586 posts
Posted 21 July 2024 - 08:12 PM
Have a look here.
https://www.theminif...date-it/page-56
