Another Compression Test Thread
18 replies to this topic
#1 mrmeds
mrmeds
  • 232 posts
Posted 14 July 2024 - 04:12 PM
Hi, my 998 engine was rebuilt in dec 2021 by a well known northern mini specialist, and has jcg cooper  kit on it too, which dates from march 2020...
When engine was rebuilt, the previous fuel pump had leaked causing petrol to go into the oil etc. Was told needed new valves - when engine was rebuilt.
Felt it was lacking oomph about a year ago , and another more local mini specialist old me they thought it was lacking compression on one or more cylinders... so sent it back ,and it was declared fit ... with compression of around 180  across all cylinders.
Anyway , has been lacking oomph again -so as well as trying to sort out carbs, which have been set too rich by a local garage at some type- I deceided to do a compression test.......
results are  ( by the way my numbers are wrong way round )
1.   150
2.    125
3.   135
4,   140
assuming that as number 2 is more than 10% differnent , I have  problem . Assuming its unlikely to be valve or piston. ring as they are all fairly new...
head gasket ?
No signs of water in oil
#2 weef
weef
  • 448 posts
Posted 14 July 2024 - 06:22 PM
As I have just said in a previous post do a cylinder leak down test as a opposed to checking compression ratios to establish if you have a problem in this area.
#3 mrmeds
mrmeds
  • 232 posts
Posted 14 July 2024 - 06:51 PM
so would need a leak down etster and a supply of compressed air ..... ? .....in which cas eits off to find a friendly garage !
#4 weef
weef
  • 448 posts
Posted 14 July 2024 - 07:11 PM
Yes thats about the size of it, make sure the garage has a good quality tester, as shown, one that operates at 100PSI, and work from the results you get.
#5 MrBrown
MrBrown
  • 41 posts
Posted 14 July 2024 - 07:18 PM
Quick question: are your compression tests with the carb wide open?
#6 Avtovaz
Avtovaz
  • 1,172 posts
Posted 15 July 2024 - 07:49 AM
yes so the air has the best chance to be forced in.
#7 sonscar
sonscar
  • 2,886 posts
Posted 15 July 2024 - 11:32 AM
Have a poke at the tappets first as the added oil made little difference.Its cheap and easy to do.Steve..
#8 mrmeds
mrmeds
  • 232 posts
Posted 15 July 2024 - 06:19 PM
yes
#9 mrmeds
mrmeds
  • 232 posts
Posted 17 July 2024 - 04:40 PM
ok ... so I was topping up the dash ots with oil - so had an idea..... i used some  dashpot oil to run a line of oil along the join of the head and the block.... then started the engine ...
low and behold ... very fine bubbles appeared in the oil around the gap between spark plug one and 2 ..... when I increased revs ... bubbles got a bit bigger... so obviously a very slight leak in head gasket ..... is it enough to worry about , or should I wait until it becomes more of a problem -- bearing in mind I lack the skills to change my head gasket. ( not that i've tried  )
#10 Lplus
Lplus
  • 785 posts
Posted 17 July 2024 - 07:28 PM
Might be worth checking how tight the head bolts are.  I have in the past had a minor leak at one end of the head of a mini I just bought due to a bolt not being anywhere near to spec.
#11 sonscar
sonscar
  • 2,886 posts
Posted 17 July 2024 - 07:33 PM
A leaking gasket is unlikely to heal up and if left could burn a track in the head or block.As for skills it is not massively technical but does require some tools.Steve..
#12 cal844
cal844
  • 9,576 posts
  • Local Club: TFMOC
Posted 17 July 2024 - 09:05 PM
Fit a new head gasket (or get a garage to do this). It can be done in 2 hours (using buzz gun for removal then refitting and torque with calibrated torque wrench).
Time quoted doesn't account for head skim.
Edited by cal844, 17 July 2024 - 09:07 PM.
#13 MrBrown
MrBrown
  • 41 posts
Posted 18 July 2024 - 12:07 AM
I’m with the others on this one. Check the head stud nuts and see if they’re all torqued to spec first. If you still have a problem after that, change the head gasket. Watch some videos on how to do it. No skills required. If I can do it, I’m pretty sure you can too! I use a little copper gasket spray on mine since I have had some issues with gaskets. If the head gasket does not correct the issue, it could need a skim.hopefully it’s just a not so tight head nut!
#14 mrmeds
mrmeds
  • 232 posts
Posted 18 July 2024 - 05:22 PM
thanks ... will try torque first .... what am i aiming for.  40lb ?
#15 Lplus
Lplus
  • 785 posts
Posted 18 July 2024 - 05:59 PM
My '69 - '85 Haynes says 50 lb/ft.  The pre '68 Haynes says 40lb/ft.  Personally I go for 50
