![Photo](https://secure.gravatar.com/avatar/b82b14afa2011f33e3cfa0f286807c4e?s=100&d=https%3A%2F%2Fwww.theminiforum.co.uk%2Fforums%2Fpublic%2Fstyle_images%2Ftmf%2Fprofile%2Fdefault_large.png)
Minispares Evo Lsd
Posted 10 July 2024 - 01:05 AM
Anyone using one?
If so how did you relieve the case and diff housing so it fits? Does it need relieving?
There's a fair chunk of cash difference between the Evo and the NXG, is the NXG better material spec?
Lots of questions I know but a bit of forward thinking never hurt 😁
Posted 10 July 2024 - 04:12 AM
Then there's the way they work to take into account and the fact that the plated type are not maintainence free and are more aggressive in use.
Edited by imack, 10 July 2024 - 04:13 AM.
Posted 10 July 2024 - 07:04 AM
The Minispares plate-type LSD is more or less the Tran-X unit and Tran-X was taken over by Quaife some time ago. I have the Tran-x one but only for competition. I never felt it necessary to use one on my road-going SPi. On my other Mini I think that the Tran-X is very nice to drive on the track.
On the other hand I overheard a BMW-comps-engineer say at the track that the worm-and-spindle LSD are not really slip limiting and therefore were useless in competition. Full stop, I cannot commend on this as I do not have any experience with worm-and-spindle-LSDs.
Posted 10 July 2024 - 09:10 AM
Posted 10 July 2024 - 11:03 AM
I have run with a Plate type LSD in a road car and it was horrible. On the Track, a different matter.
For Road use, I've found the ATB to be the bee's knees, but while it would be better than an open diff for track use, an LSD is definitely better here. I'll never ever go back to an open diff.
Posted 10 July 2024 - 01:43 PM
So if the Evo diff is tran X aka quaife then I wonder why quaife don't list it as one of theirs, eg for spares etc
They only list atb diffs for the mini.
Tran X just going out incognito via minispares!
Posted 10 July 2024 - 03:06 PM
Is that what r.tec meant by this?
I read it as they were similar but not necessarily that the Evo was built by Quaife? Quaife are vey clear that they only sell the ATB through Swiftune, why would they be secret squirrel about the plate diff? Their website doesn't mention any other diff for the Mini.
Posted 10 July 2024 - 03:57 PM
You also asked about relieving the gearbox case. Yes, I had to do this and also had to file down the boltheads of the diff
2017-09-09 (2)kl.jpg 126.96K
1 downloads
2017-09-09 (3)kl.jpg 145.41K
2 downloads
Posted 10 July 2024 - 04:17 PM
That's not much relieving compared to what I had to do back in the day with the Salisbury.
It was in a remote case though so maybe they were different regarding the amount of "meat" round that area.
Posted 10 July 2024 - 05:02 PM
Who makes the Evo diff then I wonder?Is that what r.tec meant by this?
I read it as they were similar but not necessarily that the Evo was built by Quaife? Quaife are vey clear that they only sell the ATB through Swiftune, why would they be secret squirrel about the plate diff? Their website doesn't mention any other diff for the Mini.The Minispares plate-type LSD is more or less the Tran-X unit
I doubt minispares are tooled up for this 😁
The Evo uses the large diameter output shafts too (ala salisbury) whereas the NXG uses shafts to fit non "S" side covers.
Has Salisbury risen from the grave via minispares 😁
Edited by Gaz66, 10 July 2024 - 05:08 PM.
Posted 10 July 2024 - 05:19 PM
Mystery solved. "Ingenious design, meticulous engineering and careful development by Transmission Services of Redditch has culminated in the production of an LSD unit that eclipses most of those currently available."
Posted 10 July 2024 - 07:22 PM
It may well be Quaife, but doing them under a licensing arrangement exclusively for Mini Spares.
Where is that from poolguy?
Posted 10 July 2024 - 07:26 PM
Minispares website.
Posted 10 July 2024 - 07:28 PM
So the Evo is getting up to Salisbury vintage. 😁
Edited by Gaz66, 10 July 2024 - 08:21 PM.
