Unless you can get it properly Helicoiled, thus is what I suggest.
Drain all the oil out,
Jack the car up as high as it will do on the RH side so that any oil residue in the sump drains away from the drain hole.
Thoroughly clean the remains of the threads in the drain hole using 'Brake and Clutch Cleaner' with a 1/4" paint brush and clean rag.
Clean the sump plug threads similarly.
Clean the sealing washer similarly.
Mix Araldite in exactly the right amounts and liberally coat the sump plug threads and washer.
Re-install it and turn it until it's in as far as it will go.
Leave the car jacked up for 24 hours until the Araldite has fully hardened.
Let the car down, re-fill with the correct oil and drive it. It will not leak.
At the next oil change, decide whether to repeat this or to fit a Helicoil. I promise you it will work as I had to do it on a rally Mini many years ago when the thread was stripped a couple of days before the event. It didn't leak!
