Best Grease Gun And Grease
12 replies to this topic
#1 JDMRoverMini
JDMRoverMini
  • 96 posts
Posted 26 June 2024 - 02:20 PM
Realized I need to grease where it’s needed. Want to make sure I get the swivel hub, radius arms, and upper support arms.
What’s the best/easiest to use gun to get? Was looking at this: http://www.minispare...k%20to%20search
Also, what grease do I buy?
#2 Icey
Icey
  • 1,551 posts
Posted 26 June 2024 - 04:40 PM
Don’t bother with new grease guns, most are rubbish, try to find an old Wanner brand one. Even at decades old the ones I bought for a few quid on eBay are far better than the new one I had.
As for grease, I’m sure there’s an official spec but most just use general purpose lithium grease for suspension joints.
Edited by Icey, 26 June 2024 - 04:40 PM.
#3 imack
imack
  • 2,105 posts
Posted 26 June 2024 - 05:10 PM
Totally agree with the above statement regarding modern grease guns being rubbish.
I found this old Tecalemit grease gun in the garage of the house I bought. Best grease gun I've ever had. No oozing oily grease mess everywhere when left stored like modern grease guns.
#4 lsto
lsto
  • 595 posts
Posted 26 June 2024 - 05:11 PM
Whatever gun you buy, get a flexible rubber hose, just makes getting on the joints a thousand times easier than the fixed metal pipe.
#5 Chris1275gt
Chris1275gt
  • 938 posts
Posted 26 June 2024 - 05:32 PM
Agree totally with getting a old Wanner grease gun.
#6 Shooter63
Shooter63
  • 1,027 posts
Posted 26 June 2024 - 05:52 PM
Another Wanner fan here, ebay, auto jumbles are your hunting grounds.
Shooter
#7 Gaz66
Gaz66
  • 896 posts
Posted 26 June 2024 - 07:39 PM
I bought a cheap eBay one, silver line or some crap like that.
It works really well but .....once it locks over the nipple it's a two handed, feet against the car job to pull it off.
#8 eric67
eric67
  • 113 posts
Posted 26 June 2024 - 08:28 PM
I had the same problem and ended up buying a Zerk lock on G coupler to replace the cheap fitting. Probably cost as much as the grease gun but works a treat
#9 Quinlan minor
Quinlan minor
  • 1,171 posts
  • Local Club: LSMOC
Posted 26 June 2024 - 08:41 PM
+1 on the lock on coupler
#10 stoneface
stoneface
  • 368 posts
Posted 27 June 2024 - 04:45 AM
I use one of these.
https://www.speedygr...ons/grease-guns
#11 68+86auto
68+86auto
  • 901 posts
  • Local Club: Queensland Mini Car Club
Posted 27 June 2024 - 06:29 AM
In regards to good grease guns, I haven't seen anyone complain about Macnaught ones even though I believe they are now imported (used to be made in Australia). I've seen people recommending them on UK based forums so they can't be that bad. I have ones which are probably at least 50 years old.
#12 mbolt998
mbolt998
  • 373 posts
Posted 28 June 2024 - 07:52 AM
I have an old Wanner one but it doesn't work. Tried to clean it out but with no success. I suspect some seals have gone. Anyway got one of these from Screwfix. Cheap and it seems to work just fine. These days you can also get the grease in a sort of tube that goes straight into the gun which is less messy.
https://www.screwfix...gun-500cc/19235
#13 alpder
alpder
  • 388 posts
  • Local Club: MCR
Posted 28 June 2024 - 09:53 AM
+1 for the tubes of grease. Far less messy.
The reason the nipple sometimes doesn't want to release seems to be back-pressure from the grease. I find it happens especially on the swivels because the grease channels there are so thin that the grease doesn't flow into them at all easily. Slightly unscrewing the nipple from the hose (or the hose from the gun) releases the pressure and then the nipple easily comes away.
Lock-on nipple is a new one to me... looks a good solution and I'd like to give one a try but there seem to be a lot of generic ones (around £12) and a few - mostly still unbranded though G.Coupler comes up a bit - around £25. Recommendations, anyone?
