97 Mpi Mini Idle Issues - Possibly Aicv
electrical engine
4 replies to this topic
#1 JCUSP
JCUSP
    Starting My Mini Up
  • 1 posts
Posted 21 June 2024 - 01:44 PM
Hello,
My 1997 MPI mini currently increases the engine idle revs as the engine warms up. I first noticed the issue when driving the car, ever so often, the revs would increase when you depress the clutch to change gear. After experiencing this for a few times, I took the air idle control value (AICV) apart and cleaned it up. This seemed to make no difference and the car ended up going back into the garage for a few months due to other commitments.
Keen to get the car back on the road, I bought a new AICV with the lower elbow bracket and installed it along with a new lambda sensor, as this was advised at my last MOT. This didn't seem to make any difference and the car would then start and idle at 1200rpm and start increasing as the engine got warmer and continue up to 4/5000 RPM, at which point I'd switch the engine off. I have now replaced the throttle position sensor, water temp sensor, inlet/exhaust manifold gasket and checked that the injectors are not leaking and that there are no air leaks on the system and none of these changes seem to have resolved the issue.
The only time I can get the car to idle correctly is, once the car is warm and revs are increasing, to stick my thumb over the air pipe that takes air from the butterfly housing on the manifold to the AICV. This then brings the car back down to 900rpm and the car will sit there until you remove your thumb. To me this means that the AICV is stuck open and the ECU is not telling it to shut once the car has warmed up.
I'm now struggling as I do not know how the ECU tells the AICV to shut. I would appreciate any insight someone can give me on how to resolve this issue.
#2 viz139
viz139
  • 727 posts
  • Local Club: Irish Mini Owners Club
Posted 25 June 2024 - 09:50 AM
Why did the garage advise a lambda sensor change?
Do a compression test and check spark plugs to see if one injector is running richer than the other.
What happens if you unplug the AIVC?
#3 Quinlan minor
Quinlan minor
  • 1,382 posts
Posted 25 June 2024 - 11:21 AM
I had problems with fast running engine, particularly when hot. In traffic it could get up to 2,000 RPM.
Mike, at Croydon Minis, recommended fitting a new throttle cable.
Problem solved.
#4 stuart bowes
stuart bowes
  • 2,633 posts
Posted 25 June 2024 - 11:35 AM
I was curious what an AICV was so I looked it up
mini spares says 'After fitting the cars ignition needs to be turned on and off 3 or 4 times to allow the unit to programme itself and begin working correctly.'  .. did you do that
#5 pete l
pete l
  • 1,537 posts
Posted 26 June 2024 - 02:11 PM
The IACV steps need setting up on a T4 or pscan tool. There is no other way to get it set up correctly.
Also tagged with one or more of these keywords: electrical, engine
