Just wondering what alternatives there are on other cars that fit ?
My ones I tried to tart up , but the inside foam has broken up & getting baggy
Thanks in advance
Sunvisor's
Posted 20 June 2024 - 09:34 AM
Posted 21 June 2024 - 09:17 AM
You can still buy the original type new from the Mini specialists. I think you might struggle to get something that isn't too big from another car.
Posted 21 June 2024 - 09:21 AM
I liked one I saw once that was a transparent but coloured plastic, sort of like putting on sun glasses I suppose. no reduced visibility but reduced glare
I think it was just a home-made thing though I don't remember seeing that as a kit anywhere on sale but I may be wrong. I think that might end up being the way I go with mine
best sunvisor setup I ever had was in a Civic, they put a tiny little one in the middle for those times when the sun comes in right in the middle and you can't block it, ingenious
Edited by stuart bowes, 21 June 2024 - 09:23 AM.
Posted 21 June 2024 - 09:47 AM
apparently you can buy them
https://www.classicg...HxoCB14QAvD_BwE
but again probably easy enough to make, use the original fixings maybe
probably the only thing is getting a nice clean cut around the edges, the ones you buy are most likely machine or laser cut
Edited by stuart bowes, 21 June 2024 - 09:48 AM.
Posted 21 June 2024 - 11:59 AM
tinted ones here too, though rather more expensive, especially with tax on top when imported...
https://stevestonmot...nted-sun-visors
Posted 21 June 2024 - 06:48 PM
Shooter
Posted 21 June 2024 - 06:51 PM
Classic mini japan sell a set which bolt straight on, I think they are around £100.00, I would be tempted to have a crack myself, and probably will.
Shooter
£92.67
https://classicminis...rylic-sunvisor/
