Timing My 998 Mini
engine
6 replies to this topic
#1 jezjsa
jezjsa
  • 90 posts
Posted 14 June 2024 - 11:14 AM
Hi All.
OK i've tried to read as much as i can about Timing but i have a few questions (probably doing it wrong).
SO i have a Gunson Timing gun with a dial on the end.
With the engine idling and up to temperature, with vacuum off at distributor end (and plugged)....
For the pulley notch/marker to show on the very first tooth on the engie side i have to (currently) set the timing dial to 32!
Does that sound right or am i doing something wrong or reading it wrong?
Im' a little confused as i thought it would be reading something like 8 to 12 degrees?
Thanks in advance.
Jez
#2 sonscar
sonscar
  • 2,934 posts
Posted 14 June 2024 - 11:26 AM
Set No1 cylinder to the top on the compression stroke and see if the pulley and pointer line up first.With this established you can then ensure meaningful readings.I doubt that idling at 32degrees is good.Steve..
#3 slidehammer
slidehammer
  • 1,172 posts
  • Local Club: LSMOC
Posted 14 June 2024 - 01:06 PM
Have you got the pick on the right lead, No1 cylinder is nearest the radiator.
#4 jezjsa
jezjsa
  • 90 posts
Posted 14 June 2024 - 01:33 PM
when cylinder 1 is at the top, the notch does seem to line up (roughly) with the 0 mark - but i will double check that in a bit as its currently throwing it down...
and yes, connected and pointing towards the plug end.
#5 lsto
lsto
  • 580 posts
Posted 14 June 2024 - 05:39 PM
Hi All.
Thanks in advance.
Jez
Sounds like your doing it correctly but the timing is just out.
Make sure your timing gun is connected to cylinder 1 (fan end), everything else you have done sounds correct.
If you loosen the pinch bolt for the distributor and turn it ever so slightly then check the timing again, keep doing this until you get to 8 degrees or wherever you want it.
You may find once you have adjusted the timing the idle speed will need to be adjusted but this is normal.
If you are afraid of messing the timing up, mark the distributor base to the engine position before you start, that way you can line it up to it's original position if it does go wrong. That way you can reset it and start again if your not confident.
If you get stuck let us know. Good luck.
Edited by lsto, 14 June 2024 - 05:46 PM.
#6 68+86auto
68+86auto
  • 769 posts
  • Local Club: Queensland Mini Car Club
Posted 14 June 2024 - 10:08 PM
If it has one, the balancer may have spun.
#7 timmy850
timmy850
  • 3,222 posts
  • Local Club: MITG
Posted 14 June 2024 - 11:15 PM
If you have a couple of teeth on the crank pulley you'll need to make sure you use the zero mark, then line up the TDC mark using your dialback timing light. Alternatively set the light to zero and line it up with the 8-10 mark to start with, then check the advance up the rpm range
There's a pretty comprehensive video here:
