Sump Guard And Oil Cooler?
2 replies to this topic
#1 merther
merther
  • 147 posts
Posted 04 June 2024 - 02:52 PM
I’ve got a sump guard fitted (Scottish type)
should I be running an oil cooler with the sump guard or is modern oil (I use valvoline vr1 ok enough to deal with it) what would be the effects on not using an oil cooler with a sump guard, if any?
the car is used on the road and not a full on competition car.
thanks.
Edited by merther, 04 June 2024 - 02:53 PM.
#2 nicklouse
  • 18,523 posts
Posted 04 June 2024 - 04:11 PM
Yes the oil will not be cooled as much. But as you say road car you should be fine.
of you do fit a cooler then also fit a thermostat as cold oil is worse that hot oil.
#3 merther
merther
  • 147 posts
Posted 04 June 2024 - 06:27 PM
thanks I’ll stick with what I have.
