Hi,
My wife's '91 998 carb Mini didn't fancy going for its MOT this morning and wouldn't start. Was fine when I last drove it in March. Float bowl is empty so I'm suspecting float valve (though this looks new and clean), fuel pump or maybe a split rubber hose somewhere preventing the pump from pulling fuel through (though there are no leaks on the floor). I'll rule out the float and check the various hoses when I have time to tinker, but assuming it's the fuel pump this looks to be a right pain to access for replacement! Is it possible to replace the fuel pump with the engine in the car?
Alternatively, is there any reason why I couldn't just remove the hoses from the pump inlet and outlets and, fit a low pressure electric pump on the bulkhead instead? I know earlier cars had a pump under the rear subframe, but the engine bay looks a lot easier!
Thanks,
Tim
