K Series Fuel Pump Requirements
9 replies to this topic
#1 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 16 May 2024 - 02:23 PM
I've read that a Mini MPI fuel system works with a K Series but what about an SPI . (I have joined the 16v Club but sadly my registration has gone askew and I'm in limbo so I can neither post nor speak with management.)
#2 Avtovaz
Avtovaz
  • 1,236 posts
Posted 16 May 2024 - 04:54 PM
spi is low pressure, i cant remember exactly what it is , but its like 1 bar, mpi will be more of 3 bar. I have a r100 that was spi, and i had to change the pump when i went to 1800.
#3 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 16 May 2024 - 08:18 PM
Ah right. I didn't think I'd be lucky !
#4 Avtovaz
Avtovaz
  • 1,236 posts
Posted 16 May 2024 - 09:01 PM
why arnt you? if its on its original pump, you probably want to think about changing it anyway. Should straight swap i think.
#5 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 17 May 2024 - 07:32 AM
You mean why arnt you lucky?
It would have been nice to not have to do anything there. By 'straight swap' do you mean an MPI pump will swap into an SPI tank.?
#6 Avtovaz
Avtovaz
  • 1,236 posts
Posted 17 May 2024 - 07:58 AM
if its old, it probably will brake, and hopefully you wont be stuck somewhere now as of it. A new pump should last for ages.
#7 Ethel
  • 25,922 posts
Posted 17 May 2024 - 08:27 AM
It likely depends on whether it's single or multipoint injection, same as the A Series.
#8 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 17 May 2024 - 08:47 AM
Avtovaz, yes I see your point
Ethel, hello again.! Ok, this is a vvc so it'll be multipoint. I think I'll test the pressure from the SPI and find out what the K needs
If I could get on the 16v forum I'd be away but that's not happening
#9 Avtovaz
Avtovaz
  • 1,236 posts
Posted 17 May 2024 - 09:39 AM
i just looked it is 1 bar for spi and it is 3 bar for mpi. Thats what they relieve off at on the reg, the pump will do more. When i did my R100 conversion everyone said change the pump as its not powerfull enough.
hth
#10 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 17 May 2024 - 12:11 PM
Avtovaz, that's handy thanks. As you say, spi pump may well have the ability to produce alot more than it's regulated to but I believe the K needs 3 bar. I'll check SPI max potential but as said, it's an important item and a brand new good quality pump, probably in-line seems a good idea for reliability's sake.
Edited by Pigeonto, 17 May 2024 - 03:48 PM.
