1979 Mini Clubman Estate
22 replies to this topic
#16 lippo
lippo
  • 100 posts
Posted 09 March 2025 - 04:06 PM
I changed the front pads today as I wasn't completely happy with the braking. Turns out I had EBC pads on there, I swapped them for Mintex pads.
I also bought the Kayaba upgraded shocks front and rear. I fitted the fronts and drove the car, handled so much better and actually stopped in a straight line for the first time! Not sure whether it was the new shocks or pads, but I'm not complaining. I noticed the CV boot clip had come off so that was replaced. Fitted the rear shocks too although not driven it to see the improvement. There were Unipart shocks on the front and Girling Decarbon on the rear - no idea how old they were but they looked knackered.
I might change the seat belts over in the next few days to some Mini Spares inertia type.
Edited by lippo, 09 March 2025 - 04:59 PM.
#17 beardylondon
beardylondon
  • 1,518 posts
Posted 15 March 2025 - 01:20 PM
Thanks. I presume 4mm on the flatter areas, and 2mm around the contour parts?
#18 lippo
lippo
  • 100 posts
Posted 16 March 2025 - 03:58 PM
 Yes. A heat gun and a little roller helped immensely.
#19 Quinlan minor
Quinlan minor
  • 1,169 posts
  • Local Club: LSMOC
Posted 16 March 2025 - 04:10 PM
Might be worth taking a look at this: https://www.theminif...t-belt-fitment/
#20 lippo
lippo
  • 100 posts
Posted 18 March 2025 - 01:00 PM
 Thanks for the link, that's my earlier post about the seatbelt fitment. I've got some replacements and will look to fit them over the next week or so.
#21 lippo
lippo
  • 100 posts
Posted 24 March 2025 - 04:56 PM
 I finally fitted the red inertia seat belts and what a difference they make when you're driving, confidence-wise.
 I had some Exacton alloys refurbed recently, and fitted them today. I've always loved the Exactons from when they were on the Mini Specials, and I fancied getting a set. The refurb was an absolute nightmare and took months, and it's not even that great, but they fit in well with the overall aesthetic of the car, if you know what I mean.
 The jury is still out on them, but I'll leave them on for now, just for a change from the Mambas. I bought some wheel nut caps from Ebay, 3D printed ones. They feel like they'll fly off at over 5mph so I'll have to work out how to keep them on - any suggestions?
#22 KTS
KTS
  • 2,420 posts
Posted 24 March 2025 - 05:52 PM
Nice wheels (..and colour scheme) in my view
#23 lippo
lippo
  • 100 posts
Posted 13 April 2025 - 08:10 PM
 The wheels have been on for a week or so and I'm happy with them for the moment so they're staying, and the Mamba's are in storage.
 I replaced the front pads with some Mintex ones, the car still pulled to the left on initial braking. Whilst looking at the front hub, I noticed the CV boot clip had come off again, spewing grease onto the caliper and most likely causing the braking issue. I tried the metal clips for the boot but they wouldn't stay on tight enough so I found low profile cable ties and used that successfully.
 I took the rear drums off as there was a grinding noise coming from the nearside rear bearings and the adjuster on the offside had stopped working. The shoes were worn through to the metal on one side, and cracked on the other. I looked through the old MOT's and for the past 20 years there's been a problem with the o/s rear brakes! Funny that the shoes were much newer on the n/s. Anyway, the braking is so much better now. I did actually manage to lock up a rear wheel in the dry yesterday whilst testing the brakes, advice on her says that I should change to 5/8's brake cylinders. I assume they're still the original 11/16's cylinders from the 998 Clubman.
The bearings were drier than a nun's ..... and look to be original 1979 ball bearing type. Both sides were replaced with Timken bearings.
 I bought on of those bulkhead blanking plates (from Australia) and fitted it. Looked much better. I then decided to fit the Newton Commercial bulkhead soundproofing which completely covered the blanking plate completely. I don't think I fitted it perfectly, but the car isn't perfect so it matches nicely.
 I also wrapped the top of the LCB for a couple of reasons. I reduce the heat slightly in the engine bay and also the cabin, and there's less chance of me being burned by accident when working on the car. I'll wrap it more fully when I get the chance. There were a few issues with bulbs and poor connections in the new PCB which caused the ignition light to not come on and the battery to not charge, and the right indicator was annoyingly intermittent. All solved by ensuring the connection tabs made a good contact with the bulb holders. Funnily enough, the oil pressure light stopped working, being fixed by replacing the faulty sensor in the block.
 I'm due to get new seat covers (been waiting 6 months, absolute nightmare) and I've ordered a moulded estate carpet from Mini Spares, which I assume is the Newton Commercial one. I may remove some of the closed cell insulation as it distorts the carpet somewhat - I'll see when I start fitting it. I'll obviously fit the brake cylinders and also the new 55mm wheel studs I realised I needed when trying to fit the 1275GT Mini Spares drums.
 I also bought a sealable box for the boot to carry essentials. I've been carrying 5 litres of petrol as the car's run out of fuel twice (not me!) and it smells pretty strong. I've also got a jack, impact wrench, spanners, screwdrivers, fuel additives, multimeter, socket set, 500ml of 20/50, some water. That was like the Generation Game for me there, I think I've forgotten a few things. What has anyone else got in their boot that I'm missing?
