Nrg Quick Release Hub
Posted 09 May 2024 - 04:09 PM
Thanks.
Posted 09 May 2024 - 06:34 PM
What steering wheel do you have? I had planned on doing a Momo hub adapter on the column, then a quick release on the hub adapter. You should be able to do the same but depending on your steering wheel choice.
Posted 09 May 2024 - 07:04 PM
Yes it is complex. You need to know the year of mini. And then the make of steering wheel and that wheels bolt pattern and BCD.
It may be easier to change the wheel.
Posted 09 May 2024 - 07:38 PM
Posted 09 May 2024 - 09:17 PM
Posted 09 May 2024 - 09:33 PM
Posted 10 May 2024 - 02:17 PM
Posted 10 May 2024 - 02:44 PM
Posted 10 May 2024 - 02:46 PM
Posted 10 May 2024 - 05:36 PM
Does it have the same PCD as the hub? You have not provided any info on that.
Posted 11 May 2024 - 10:30 PM
Formula wheels have a bespoke pattern that aren’t compatible with anything else
Momo is 6 x 70mm
Nardi is 6 x 74mm
There aren’t any common adapters from Astrali to momo. If you need to use the quick release you’d probably need a new momo type boss, then the quick release, then a new steering wheel with a momo pattern
