Dip Stick Length
4 replies to this topic
#1 steve1978
steve1978
  • 108 posts
Posted 04 May 2024 - 02:14 PM
Hi,
could anyone tell me what the correct length of the dip stick is for a 998cc cooper mk2?
#2 nicklouse
  • 18,279 posts
Posted 04 May 2024 - 09:05 PM
They are all the same. Except very early 850s, MPIs and autos.
what’s your problem?
#3 steve1978
steve1978
  • 108 posts
Posted 05 May 2024 - 09:47 AM
I have a sneaky feeling that the dipstick might not be long enough!
basically, the level is about half an inch below minimum, when I top it up it virtually spits it back out and ends up back at the same level, I am thinking maybe I’m overfilling it due to incorrect dipstick. Then pressure release valve is spitting it out
#4 Icey
Icey
  • 1,533 posts
Posted 05 May 2024 - 09:51 AM
Pressure release valve is internal and volume won’t affect it. Probably more that you’ve got a leak that only becomes obvious when the oil is full, something like diff outputs which are ‘higher up’ in relation to the oil level.
#5 nicklouse
  • 18,279 posts
Posted 05 May 2024 - 04:10 PM
Ok for you to check you don’t have the wrong dip stick.
